definitely check your crank sensor, totally agree. Had exactly the same problems on mine about the same time and wasted lots of money replacing things I didn't need to.
The bad news is that the crank sensor (sometimes called cps or crank pos sensor) is a bit awkward to get to. Most ppl take the oil filter off, so not something to do for fun.
The good news is, if you search the forum for crank sensors, someone- i forget who- posted a file that basically shows you what results sticking a meter between the pins of the connector from the crank sensor should give. This is good news because while the cps is in a bad place, the wires from it go to a 3 pin plug that joins the main wiring loom near the top of your engine... So you can test it before you buy one...
Apparently there's some confusion in GSF's system and they may not give you the right part, but unless you know what it looks like you won't know til you fit it!
I got mine from Andrew Page, local branch had it on the shelf, and it was about 20quid.
There's loads about crank sensors on the forum if you do a search, including how to get at it and the story about gsf part codes...
The Golf boys chuck a relay about as easily as ppl point at beezer coil packs for this problem too. 172 sticks in mind? Don't remember, it's grey tho...
