The car has been left in the sun for most of the afternoon. As I started to drive home from work, the horn jammed on. If you wiggled the horn button around, you could get it to stop, but any vibration, bump in the road, or indeed just staring at it would set it off again. I ended up pulling the fuse so I could drive it.
I'll be popping into the stealer first thing tomorrow, but I was wondering if anyone else has had this problem before, and if it's a quick, simple fix?
P.S. As a side question, is the handbook supposed to fit in the slot in the glovebox? Mine doesn't
