New brakes!!
Samibizacupra07
69
Bristol
I am looking at replacing all brakes and pads, I have a 1.8T Cupra with stage 1 remap, I will be going stage 2 in the near future so I want some decent brakes. Can anyone recommend any?
Iv been looking at these for the front
http://www.demon-tweeks.co.uk/perfo...rbo-groove-performance-brake-discs-front-pair
These for rear
http://www.demon-tweeks.co.uk/perfo...urbo-groove-performance-brake-discs-rear-pair
Pads I am still unsure of I'm looking at yellow suff and red stuff, it says red stuff is designed for cars over 200bhp, doesn't say that on the yellow stuff can anyone advise?
Thanks in advance!
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
Just had all mine replaced actually. Here is what I went with. Very very pleased atm, initial bite is superior to the brembo max discs they replace. Ferodo ds2500 are class, expensive, but worth it. Need to go and bed mine in tonight thinking about it.
Ferodo DS2500 pads front
Ferodo Premier pads rear
CRN grooved discs all round
Motul RBF 600 brake fluid
Don't forget a set of new retaining pins, they are the same of the MGTF ones and they are on ebay :D
vroomtshh
4,222
Dreghorn, Scotland
Road or track use?
Road - Standard discs, with DS2500 front pads and standard rears
Track - Standard discs, with DS3000 front pads and standard rears
And some fresh fluid - ATE super blue or RBF660
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
Road use, but I give them quite a punishing!
Where did u buy the parts from Kahn?
Will post links when at home.
DS2500 pads- Camskill
Everything else on ebay.
DS2500s will cope with anything you can throw at them on the road
More than good enough for stage 1 power on track too, if you just doing a track day etc. I've never had a problem with fade. Would have thought the DS3000 would be for competition use etc.
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
No doubt, but if you like 2500s on track, you should give 3000s a go. The difference is phenomenal
What are they like day to day?
Anyrode, OP. I have not seen them cheaper.
DS2500 for the fronts.
http://www.camskill.co.uk/products.php?plid=m49b0s4055p53539
Retaining pins
http://www.ebay.co.uk/itm/Brake-Pad...arts_Vehicles_CarParts_SM&hash=item257185274f
Fluid- I bought three bottles, but the guy only used 1 and 3/4. So not sure how much you actually need.
http://www.ebay.co.uk/itm/MOTUL-RBF...41?pt=UK_Motorcycle_Parts&hash=item3cc8814161
Rear pads
http://www.ebay.co.uk/itm/REAR-Fero...Cars+Type:1.9+TDI+Cupra+R&hash=item43b0cc7fde
Discs
http://www.ebay.co.uk/itm/SEAT-IBIZ...arts_Vehicles_CarParts_SM&hash=item255335a147
You will need to bed these pads in properly, do 200 or so miles or normal driving. Then find somewhere quiet and do some 70-30 stops, medium pressure about 10 times, let them cool and repeat. Various ways of doing it, doesnt seem to be one set method. Think the idea is to heat cure the pad material.
Samibizacupra07
69
Bristol
Cheers kahn! Not to bad for all around price!!
Theres some bad drivers out there sam!! Yeaa cupra's all good just been through MOT flew through!! But gonna do the brakes very soon! Hows ur beeza??? When u in bristol next?
