Turbo timer @ IBIZA MKIV Cupra
melodystyle2003
Hello
I have a little problem with a BLITZ FATT (full auto turbo timer) which i bought.
I Dont know which wires are the ignition one and the hanbrake's wire..:blink: Unfortunately no blitz harness for Seat or VW exists.
I would be gretaful if you could help me on this.
Regards George.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
was gonna say just give it a mile or so or a couple of mins after hard pasty or if its a derv no need as the temps dont get that high for real damage to occur
Ric 2001
Need an ID-ten-T form
Also Cupra has a Cat 1 alarm. Installing a turbo timer will then require an after market product to put the car back into the bracket of Cat 1.
As stoneyfordNI says just give it a mile or so or a couple of mins after hard pasty.
Also looking at your power graph, guessing its a derv?
melodystyle2003
I knew that, but its more relaxing to leave it cooling it self .
Anyway the weather its crazy hot here so i wont even run the car
Ant FR
2,861
Kent
you don't need it as the 1.8T has a cooling pump that continually pumps the water around for about 3-5 mins after turning it off, you can hear it if you listen for it
melodystyle2003
Yes but only for water,cause oil stop flowing and with that temperatures it burns (if you turn off your car rapidly)
Ant FR
2,861
Kent
simple don't turn it off stright away, you will have major hassle getting round the alarm without bodging it, plus you swill still need to hang around the car for it to be turned off then armed. Not really worth it, id you ask me
melodystyle2003
Yes i know that cooperation with immobilizer will be difficult.
Many have install greddy or blitz turbo timer by sacrificing the remote key...
On second thoughts i ll put it only when i found i safe way..
off course i DONT turn off my car immediatelly but after 2'
WeeJase
pert
Jun 2, 2001
8,595
is it not illegal to leave a car running un-attended?i know at work we get around it due to having beacons running off the engine ,but i'm pretty sure its against the law
bigjode
504
Isn't that just a waste of money?
How many people with much more power don't have have timers, and turn off engine straight away, AND have never blown a turbo?
Dario
DUBing :)
Jan 22, 2006
385
Zagreb,Croatia
here in croatia it is legal to leave a car running :clap: ,no penalty:)
