Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
well i've ordered a 007 in blackcan't wait to get it now
i've read the fitting instructions from the forge website but i'm still a bit confused - i've done a search to see if there is a fitting instruction for the ibiza but cannot see one (there's loads for a leon!)
can anyone give me an idiot style fitting guide?? i've heard about relocating it to the "cold side" will help with the noise but looking at the relocation thread don't want to be forking out another £100 - what the best position to put it for more noise?
u dont need 2 fork out another £100 forge dont do a relocation on the cold side for the ibiza all u need is a t piece cut the boost pipe from the intercooler to the inlet manifold then with sum clips but the t piece in and then run a vac hose up to the where u bypass the n249 valve and get 2 25 mm blanking plugs to put in the pipes where u remove the bosch valve then put the split r valve to fully amosphic and thats it![]()
Does that really work and not cause havok with the ECU? if so could you do a proper guide????
i've got a pipercross panel filter so hoping to hear a bit of noise
can't wait to be set loose with a load of tools on the car![]()
