Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Fitted a Toyo tip last weekend, so now the dv is shifted further away from the maf. Cos its a tight fit it has to go in reverse otherwise the pipes don't fit.
Prefer it in standard though. Seems to be a bit rough in gear change since. Maybe I didn't tighten something back enough! ha
so what do you guys think of this??? ive just bought one and was guna put it in reverse but now i dunno
http://www.seatcupra.net/forums/showthread.php?t=301591
first ive ever heard it loses power... not sure how it could?
If the car's remapped and too soft a spring is used then I guess it could push the valve open slightly?
so i fitted mine in reverse, and there was the slightest noise, not much different to the little whoose u get when its fitted normally....
i seem to have a good boost but dont have a boost gauge???
anyone else had a quite noise and found the reason?? ive got a green spring
