Hey everyone!
I've started to fix some fault codes from my vehicle and this one is bothering me right now. The vehicle is a 6K2 Cupra Cordoba.
I've got this fault code at the moment that i am trying to get rid off;
00812 - Brake Pressure Release Solenoid (F84) 35-00 -
I've also got some other ones too;
00778 - Steering Angle Sensor (G85) 49-00 - No Communications
01312 - Powertrain Data Bus 37-00 - Faulty
The steering angle sensor does actually have communication since vag-com knows the steering angle on measuring blocks so i guess it just needs some calibration. On the data bus issue, i have no idea where it comes from.
Anyways, i got the "00812 - Brake Pressure Release Solenoid (F84) 35-00 - " up next.
Would bleeding the system or new brake discs and pads be any help? The F84-solenoid should be in the brake booster, so it's not the easiest thing to replace and finding a spare brake booster seems impossible atleast with the same spare number.
Any tips on fixing this 00812 fault code? I'm also very thankful if there are tips for the other ones too.
Sorry, if my English isn't perfect
