01314 Engine Control Module No Signal/No Communication Int - ECU Fault?
Traction
210
Hi,
I've got this error on my Mk2 leon.
2.0 TDI
01314 Engine Control Module No Signal/No Communication Intermittent
I'm getting startup issues when this appears.
Garage have identified it as a fault in the ECU.
Does the error code help identify the issue or is it just a generic ECU error?
All opinions welcomed :)
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
I'd start with the engine control relay or wiring to it before I put it down to the ecu itself which lets face it - very very rarely go wrong.
Traction
210
I do know that they spent time testing the wiring and they checked the relays
In the case of an ECU fault, is a repair a valid fix or is it just a temporary thing?
Would you know of any reccommended places for repairs?
Found this place
I did ask if they checked the relays and I've been told they did.
I do know that they spent time testing the wiring.
Found this place
http://www.ecutesting.com/catalogue/product/volkswagen_golf_ecu_engine_management_eem012221.html
leaving aside the cost and time, would it be better to get my own fixed or get one of their pre-repaired units?
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
You can spend an age testing wiring and relays but if you don't do it correctly then you never get a penultimate result.
I've seen loads of cars with apparently condemned ecus which are nothing more than a chafed wire, faulty relay, popped fuse etc
Never have I seen a faulty edc15 or 16 ecu.
Unless the repairing company removes the immobiliser off a replacement ecu you'll have to get yours repaired, which should be a permanent fix.
