02j box release bearing or push shaft?
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
Hi all,
Just a quick question, does anyone know whether the 02j box has a release bearing as pert of the clutch mechanism or is it a push rod into the centre of the drive plate??
Thanks,
Jon
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
okay, not good news!
recently whenever i press the clutch fully the gearbox does not totally disenguage, getting really annoying now, running a spec 6puck clutch so its getting really hard to change gear!
anyone had these issues before?
RobT
Full throttle trip
Nov 30, 2001
2,557
9
Congleton
could be several things
1. clutch cable stretched / limit of adjustment (if yours is cable operated) - need new clutch cable
2. leaking hydraulics - master cylinder or slave cylinder or piping
3. damaged arm on which the release bearing sits
4. damaged / worn out release bearing
