i stopped using the 99 ron stuff after it helped along the dying coilpack to die even more and also because of the running cost involved. When i was using it, was great. Better pickup and smoother running (when the dying coilpack wasnt misfiring at me)
Tip: dont use Redex, my engine didnt like this at all!
I would never use Tesco fuel, its rubbish, and over a long time of use can effect your car. You certainly get worse MPG.
I always use shell, or BP if im not close to a shell garage.
Cheap supermarket stuff does not have the same aditives in the fuel as the top brands (shell/Bp) so your car wont run as well, will be less nippy and worse on fuel with cheaper brands.
A lot of modern diesels, once they get higher mileage have trouble with injectors if being run on supermarket fuel, due to the lack of lubrication in cheap fuels. Run them on top brands and there is a big difference, there is research out there to back this up.
Where do you think the supermarkets get the fuel from? Shell, BP etc.
