1.2tsi problem, Help please
lexu
49
malta
Hi lads, today i was driving my 1.2 tsi it have about 19k on the clock and when i tried to had a go since the road were clear it started like popping from the exhaust & knocking, it does it mostly from 3rd gear onwards after about 2k revs,
i'm thinkin it's a turbo problem or a boost leak, anyone had this problem before? my car it's not remapped yet and im goin to take it to the dealers but i want to have a second opinion
BF95
442
Coventry
Sounds like it's over fuelling on a cylinder, can you make it do it all the time? Or was it a one time thing?
lexu
49
malta
It was doing it all the time, problem solved now took it to the dealer, apparently it was the ignition coil that faulted
Feb 8, 2011
743
That seems to be more common on the 1.2 TSI than it should be. There are reports of failures on Skodas I've seen and znww5 on here has gone through more than one IIRC. At least it seems they can be bought for not too much money.
znww5
146
Did I hear my name? :)
My problem (on a 2011 1.2TSi) was that the rubbish quality HT leads were shorting across, especially in the wet, and that was killing the ignition packs.
It took SEAT 3 attempts, but the fix was to change all the HT leads, route them away from main heat sources and fit corrugated plastic tubes over them. No trouble since, but I believe there was a TPI for arcing between HT leads.
I still can't believe they fitted such trashy leads to a brand new car!
