1.4 sport engine trouble please help
xshabzx
Hi there gang only been about 4 days since getting the ibiza sport and its started to develop a juddering/ lack in pick up when accelerating.
I did change the spark plugs ( 3 prong ones)
oil
oil filter
air filter
on the second day of purchasing you know just incase it hadn't been done.
Any idea as to whats causing this problem many many many thanks..
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
well youve pretty much done everything i would of suggested
did you adjust the sparkplugs at all? they should all be around 0.8-0.9 ml. i had to do that on mine
xshabzx
No did not adjust the park plugs, i dont have a feeler gauge or anything do the original seat ones have to be adjusted?
DEAN0
Old Git
Feb 1, 2006
5,439
Preston - UK
oil
oil filter
air filter
Did it do it with the old plugs in ?
If it did not I would put the old plugs back in and see if it cures it.
Even brand new spark plugs can be faulty
xshabzx
put old ones back and same problem quite puzzled now.
goin to try clean throttle body tmrw and see where that gets me
thanks..
RUM4MO
8,110
1,124
South Scotland
It sorts as sounds a bit like a coil could have failed - maybe it got damaged when you replaced the plugs - just a thought!
xshabzx
Nope no damage went down to a garage and got it put on a comp came out with the following codes
p1564 throttle valve control
p1142 load value below lower limit
p1545 throttle valve control system
p1136 system too lean
goin to clean egr and throttle once more as cleaning the throttle yesterday made it a tad better.
will post some pics of this while im cleaning as i can find a post on this entire forum on how to clean egr or throttle (with pics)
xshabzx
can someone get me a part number for a throtlle body ibiza sport 1.4 16v 2005
thanks in advance
xshabzx
cleaned the throttle and egr car still jerky between 2000-3500RPM.
took picturs but cant post them as im a newbie...
mechanic suspects its an airleak after the throttle body so that what we are goin to look for next.....
thanks for ALL the reply's :shrug:
