16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
might have something to do to the small breather hose attached to the stock airbox , wat did u do with it when fitting the dynatwist
lethargic
Hi
I've got the same fault code along with
17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean
This started happening after I had my Blue Flame exhaust from the group buy a while ago. It was running ok but slower until about an hour ago when I had the codes read and reset. Now it stutters when I put my foot down.... too lean!! Does anyone know what this could be? I've been told by the garage who first noticed it at my MOT that it could be the MAF sensor (or something like that).... HEEEEEEELP!
cupra-c_ya
I love da boost!
Oct 4, 2004
716
devon
img124.imageshack.us
Hi
could very will be maf sensor, read this >>> http://communityhosting.net/tdiclub/index.php/Mass_Airflow_Sensor
could try unplugging the maf sensor and see how it drives, only do this for a very short time, hope this helps
Santos_V
http://wiki.ross-tech.com/index.php/16795/P0411/001041
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Solutions
* Check Fuel Pump Relay (J17)
* Check Hoses/Pipes to/between Components
* Check Secondary Air Injection Pump (V101)
* Check Secondary Air Injection Pump Relay (J299)
* Check Secondary Air Injection Solenoid Valve (N112)
Kris
ESTATE! I'm Getting Old!
Nov 21, 2003
808
North Essex
bank 1 too lean could mean you need a new Lambda sensor.
I'm not sure where the Secondary Air Injection Pump is on the Ibiza but if its the same as My old Leon then you need to make sure that your engine tray is there! if not the pump gets wet and fooked £300+ for a new one!
