Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
thats it, replace it with silicone and it will be sorted
Guys I have been having a few problems lately.
A while back my engine management light came on and with the help of VAg-COM i had the follwoing fault code
17536 P1128 Long Term Fuel Trim mult.,Bank1 System too Lean.
I had cleared the code for the time being and so far it hasn't reared its ugly head again.
Then quite recently i have had this code flag up.
16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected
I have been getting help you guys in the Mk3 section (mainly HoocH) on this part and think i have come across the problem causing this.
Then when i did a final check last night on my car to clear what i thought was the 16795 fault code, it actually came back with:
17584 P1176 O2 Correction Behind Catalyst,B1 Limit Attained
Any idea if all this is all related and what i could do to try and fix this. Bit of a novice on engines but eager to understand whats going on.
Or should i just take it to somewhere like Jabba (15 miles up the road from me) and get them to fix the problems.
Any advice appreciated.
The pic that ya just made, remove the hose, cut the broken or damaged section
and attach it agian. Could be that ist leaking there.
Bas
Its stretched as it is, so i think i'll need to replace it.
I had the same problem also with some hoses, it was stretched. I removed the bad sections and attached them, just in case.
Some hoses will start leaking and giving fault codes.
The code Sec.Air Inj.Sys. Incorrect Flow Detected had that one last year.
The dealer couldnt find anything. So i did some searching myself and removed the bad sections. Havent had that problem anymore.
Bas
order some from Forge, or demon tweeks for example, it'll be there in a day or so. Dont bother trying to trim and refit, just refit the whole thing at the same time.
Erm, I used 3 iirc, i ordered 3, 4 and 8, and thats about all the right sizes.
