17763 - Cylinder 1 Ignition Circuit: Open Circuit
Munky
108
Northants
Ok i've just fitted 4 new coil packs and it seem's to have sorted my problems.. Shame another problem has now come up.. Im getting the error:-
P1355 - 35-00 - -
Which im guessing is the circuit connected to the back of the coil.. They all seem to be connected ok so im abit stuck.. Any ideas?
Munky
108
Northants
Swapped the coilpacks around and still having probs.. I've just taken the new ones out and replaced them with the old ones and the 17763 fault has now gone and im back to the misfire i had before..
thewiizard
Tarmac Tantaliser
Jan 15, 2007
486
Rugby, Midlands
www.tbfh.org
mate did you ever suss this?
Mines just started doing the same thing, open circuit on cylinder 1, random/multiple missfire detected, missfire detected on cylinder 1 and now also missfire on cylinder 2.
Replaced coilpack on Cylinder1 same problem. Only seems to happen when the car has been running for a bit and is hot, when it cools down the problem goes...
if i take the pack out from cylinder 1 with the spark plug connected and earthing to the head I get no spark on the plug whatsoever with the new or old coil packs. I've tested the wires and all seem to have good connections whether it be live or earth all four seem good.
I've read on the net about splicing a new earth into the brown wire found in the coil pack connector however not sure if this is what's required.
Any advice/suggestions appreciated.
thewiizard
Tarmac Tantaliser
Jan 15, 2007
486
Rugby, Midlands
www.tbfh.org
Yep. The plug is good condition with all gaps the same. The cylinder runs sweet up until a certain point where the misfire kicks in then i have no spark whatsoever.
Its funny watching VAG-COM log all the misfires detected on 1, within 2-3 seconds its around the 100-130 mark :)
Keep em comin'
thewiizard
Tarmac Tantaliser
Jan 15, 2007
486
Rugby, Midlands
www.tbfh.org
I have noticed a bit of oil around the inlet manifold on that side of the engine thinking about it, which bank 4 doesn't seem to have.
Engine is fine most of the time and this does go when the engine has cooled down a bit... I'm going to check the large round connector near the gearbox/gear linkage area to make sure that is secured...
I don't think its a compression issue as the engine runs tip top sometimes even when hot and I also can't understand why its only one cylinder and why the hell the spark disappears totally, I'm going to run a new ground to the plug tonight to see if its a resistance issue when hot.
*Continues to fathom*
markisgoing
61
cullompton/devon
hi i have had this problem but slightly different to u fine when im driving sensible but if i pull of too quick and get to 5000 revs then this is when it kicks in any ideas as it is only once in a blue moon have a mk1 changed the spark plugs and maf sensor
