18inch spare wheel
Jpfr+
43
7
Can you fit an 18inch cupra r alloy with 225/40/18 in the spare wheel well? Forgot I bought a set of 5 and had a spare. There is no tyre on it at the moment so before I go get one fitted just wanted to know if it fits in there tidy and without raising the carpet or anything as I have a rubber boot mat. Thanks
Sent from my SM-G973F using Tapatalk
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,257
1,110
Kent
Yes they do fit albeit quite tight, you'll also need the correct tool kit holder as well and even with that the carpet dips slightly.
I made a plywood spacer for mine so it all sits nice and level.
Sent from my SM-G986B using Tapatalk
Reactions: Jpfr+
Jpfr+
43
7
Will my standard fr+ toolkit not fit? Would I have to get one out of a cupra r or something?
Thai-wronghorse
Dec 3, 2015
2,257
1,110
Kent
The foam one in the FR & Cupra is totally different to the one used in the LCR.
They came with a larger solid plastic case with lid.
Also the large hold down bolt differs in length.
I should have a spare at my workshop, I'll dig it out at lunch time and show you if you want?
Reactions: Jpfr+
Jpfr+
43
7
Perfect thank you
Reactions: Thai-wronghorse
bruceR
2,578
665
Monifieth, Dundee
Should be ok as said as I have a 17” FR alloy in mine, albeit it sits a wee bit proud but not too noticeable
Thai-wronghorse
Dec 3, 2015
2,257
1,110
Kent
Mine didn't sit right on my old FR TDI when I switched to LCR wheels so ending up sourcing the correct bits.
I kept my diy spacer though and put it into my R as even as standard the levels are all over the place.
Thai-wronghorse
Dec 3, 2015
2,257
1,110
Kent
Unburied it as promised.
Reactions: Jpfr+
Jpfr+
43
7
How much you wanting for it posted? Pm me if you'd rather. And the spacer you made i take it goes inbetween the black disc and polystyrene tool tidy?
