p5yco
53
Norwich
please please can somebody tell me what the inlet for the backbox is on a 1995 ibiza 2.0 gti 8v as i am trying to find a universal backbox to fit my car with great difficulty and i need one whis is as easy as possible to fit, so if i know the size of that i can try and get a backbox as close to that as possible! thank you to anyone who can help!
don't know myself but if anyone does know it'd be useful for me too as i'm tryna decide what to do with my current magnex exhaust as i'm not sure i like it being so big!
84RNEY what exhaust do you have fitted as it would probably fit mine. is it a universal one? do you have any pics of it fitted? would be good to see.
I've got an OE back box off my 94 GTi buried somewhere in my shed. I'll dig it out tomorrow and measure it for you.
cheers mate that would be really excellent. i will also ask this, i need some new headlight and sidelight bulbs, gonna go for xenon or phillips bluevision, what ones do i need, are they H1? cheers
Depends. Early GTi's (like mine) have a single H4 bulb, as do the lower models of the range. At some point, the GTi got upgraded to twin H1 bulbs. So if you look at your lights and see one large reflector, you've got H4; if you see two smaller reflectors, you've got H1s.
found a pic of it. had the whole system fitted when i bought it. tryin to get some pics of it on car for you
how well does it fit mate, was there much modification needed as i looked at exactly the same exhaust, booked it in to a well known performance garage and claimed it wouldnt fit!! are you looking at selling the back box then?
anything will fit.
Seen someone else on here with the same exhaust on, i was gonna get it too.
The bore may be different if its universal, but then just buy a reducer to make it to the right size. I cant see it being any longer than the standard system so there should be plenty of room behind the bumper for it.
Infact thinking about it, it looks to be the same can size as the standard exhaust, itd need hanger welding to it if there arent any but any powerflow or the like can do that sort of thing
I have a Magnox Stainless back box (including an adaptor pipe) from a 97 R 8V GTI, could let you have it at £25.00 but as it's heavy you would need to be in striking distance of Cumbria or Sheffield
Chris
im afraid not i live in norwich! good price though! ibiza95 what wheels are they on your car, looks cool! anyone know about the bulbs i asked about?
I think the diameter is 50mm on the 8v and 55mm on the 16v.
Also you'll need to consider how long the universal rear box will be as the exhaust routes over the rear beam (see pic below) so you'd need to cut the old box off just where it goes in and if it's to short it'll not pop out the back and if it's two long it won't fit.
You'll also need to look at the hangers as they would need to be modded as well.
not if fitted correctly , Hayz..i had a magnex jobbie on my old red mk2 . once i'd strapped it up to stop the vibrations it was (and still is , far as I know) a really nice sounding exhuast.. :)
i went custom made, £240 cat back, no complications.
for my 16valve im considering a cat back off the shelf to fit my self, but i havent had chance to price one up yet.
Hi,
I spent last saturday fitting my magnex one as in the picture. They fit absolutely fine. You even get new hangers/rubbers with it. You get the backbox, the over axle pipe and some shite clamps which need binning and replacing with proper exhaust clamps.
You have to cut the existing pipe off leaving 80mm just before it bends around parallel towards the cat. So at the bit in line with the out section (if you understand that you deserve a medal).
Anyways - This is the only dodgy bit. I found the existing pipe a fraction too small for the new stainless to fit over, so i packed it with putty and a section from a tin can. Covered the whole joint in exhaust paste and clamped it up.
The new pipe does sound very nice- and not over-loud. The box is very big thow - gotta be carefull over speed humps.
