My little Arosa auto has stopped changing gear and offers only third gear and reverse. It otherwise drives OK.
This seems to have happened since I did two jobs on the car. The first job was changing the rear lights for the Mark II type, including re-wiring the connectors. The new lights work fine except the reversing light which doesn't work at all. No reversing light + gearbox not changing gears ... could they both be symptoms of the same electrical problem?
The second job I did was changing the pollen filter from inside the engine compartment. That was straightforward. However, there is an ECU next to the pollen filter housing and I wondered if perhaps I may have disturbed a connector or something.
Has anyone experienced this problem before? I would like some suggestions before I investigate ... I don't want to make things any worse, or in other words, more expensive!.
