1998 Cordoba Clutch creaky in hot weather?
wayki
hi -
why is my clutch pedal stiff and creaky in hot weather in traffic?
when cool or on motoroway (occasional high gear change) - there is no problem.
fluid is ok.
is this a known issue like pedal pivot / master cyclinder etc?
Ferret
23
Penzance, Cornwall
Can't give a definite answer, but had a similar problem with my Cordoba. Ended up changing the clutch cable and also the spring at the top of the clutch pedal. Cleared up the stiffness any how.
Other than that, I have no explanation as to why your clutch is stiff and creaky - unless the viscosity of the oil is weakened at certain temps because its a bit old.....?
Sorry for being no help at all!
Ferret
