check the breather valve on front of engine/camcover
these cause no end of running issues
you can check this with the oil filler cap when you remove it it sucks down again and can run even worse
ok thanks il give it a go, we plugged diagnostics machine in and there were 17 fault codes! none of these fault codes were recognised by autodata so im going to take my laptop into work and use vcds...
Hi guys.. just had the same hunting on idle prob, it turned out to be my pcv valve and a coil pack.. changed pcv put in a new set of coil packs and plugs n she's bn fine since! Touch wood lol
Hey. I know this is an old thread. But I have had a problem with my LeonFR. I was driving along the road this morning and it cut out. It doesn't want to rev or accelerate. Is this a system you guys had before changing coil pack and PCV valve (what's that btw? ). I had it in the garage for some wiring done as it threw up Fault codes of Throttle Position Sensors being High and Low. Did you have this?
