Hi All,
Had a couple of faults with the Cupra (290 nov 2018) after it was sat far a bit during lockdown.
First one was the Air con stopped working, slap bang in the middle of the warm weather! All I got was a "hissing" noise from behind the vents which went away when the AC was turned off, came back when it was turned back on (this was sorted see below)
Second was that when I went to drive it the e handbrake disengaged but it took a bit of forward throttle to actually let go (ie it went "thud!" then moved fine). Initially there was a "thud thud thud" whilst driving which went away fairly quickly but I got judder when I used the brakes (Felt through the peddle and heard, nothing through the steering wheel). This improved a lot with continued use but I got it booked into my local dealership to get the two faults sorted.
The Air con was empty, surprising for a car less than 2 years old!?! An Air Con service sorted that. The brakes were checked and they found nothing untoward, they said the pads had plenty of meat on them etc..., even drove it out and couldn't feel a thing.........I suspect they drove slow and didn't brake hard enough to notice the judder. I was recommended to just "let the brakes bed in" but after a week it still happens (I commute around 15 miles a day), it is noticeable on the first mile or so under moderate braking, beyond that I tend to use the ACC which does most of the work and it is so easy on the brakes you dont notice the judder. If I hammer it then have to calm it down to 40/30 then the judder is there.
Im wondering where to go from here, keep going and see if it goes away, or maybe look at getting the discs cleaned?? Its on PCH so it really needs to be spot on for December when I give it back (gutted).
