Nov 16, 2026
Hi everyone,
I’m looking for some advice after attempting to upgrade the front speakers in my 2018 SEAT Ibiza 6F (UK model). I’m worried I may have cut the wrong wires behind the passenger-side dashboard and potentially caused an electrical issue.
I’ll explain everything I’ve done so far.
1. What I was trying to do
I’m upgrading the factory front speakers to Focal PS165FE component speakers, which come with separate woofers, tweeters and passive crossovers.
The car has the original SEAT touchscreen head unit and standard factory sound system, not the upgraded Beats system.
My plan was to:
  • Replace both factory front-door woofers.
  • Replace both factory A-pillar tweeters.
  • Use the supplied Focal passive crossovers.
  • Keep the factory head unit and reuse the existing speaker wiring where possible.
  • Eventually install an aftermarket amplifier.
I noticed that the original SEAT tweeters have capacitors attached, presumably to filter out low frequencies. I therefore suspected that the original woofer wiring carried a full-range signal.
2. Identifying the original speaker wires
When I removed the original front-left (passenger-side) woofer, I found two wires going to its connector:
  • Red with blue stripe
  • Brown with blue stripe
The original A-pillar tweeter had two different wires:
  • Red with yellow stripe
  • Brown with yellow stripe
Initially, I couldn’t find the red/blue and brown/blue pair behind the passenger-side dashboard.
I tried accessing the multi-pin connector inside the rubber wiring boot between the door and the body, but I couldn’t get the connector disconnected.
I also couldn’t remove the original head unit because I didn’t have the removal keys.
Eventually, while examining the wiring loom behind the passenger-side dashboard, I found a twisted pair of red/blue and brown/blue wires, apparently matching the original woofer colours.
Because the colours matched and the wires were twisted together, I assumed these were the front-left woofer wires.
[Wiring loom behind passenger dashboard, showing where I found the twisted red/blue and brown/blue pair] These were originally twisted together before I cut them and crimped them to the crossover
3. What I actually did
This is where I think I may have made a mistake.
I switched off the ignition, removed the keys and made sure the head unit wasn’t playing any audio.
However, I did NOT disconnect the battery.
I then cut both red/blue and brown/blue wires behind the passenger dashboard one by one.
I connected the wires through the supplied Focal crossover as follows. Again, one by one.
Crossover INPUT (head-unit side):
  • Red/blue → Positive (+)
  • Brown/blue → Negative (−)
Crossover WOOFER OUTPUT (assumed door side):
I used insulated heat-shrink crimp connectors and heated them with a lighter to shrink the insulation.
I didn’t check whether the original woofer stopped working immediately after cutting the wires, which I now realise would have been a useful way to check whether I’d actually interrupted the correct circuit.
[My current crossover installation showing the cut wires, crimp connections and crossover input/output]
Here the wires coming from the head unit went into the input and the wires coming from the door loom went into the output.
4. What happened when I tested it
After making these connections, I tested the speakers.
The front-left woofer still plays audio.
I then tried connecting the Focal tweeter to the crossover’s tweeter output, matching positive to positive and negative to negative. These were temporary connections held by hand, not permanent crimps.
The tweeter only produced a very quiet static/crackling-type sound rather than playing music properly.
At this point, I started questioning whether I’d actually cut the correct woofer wires.
I’m concerned that the woofer might still be working because I cut an entirely different pair of wires, leaving the original woofer circuit intact.
5. Three new dashboard warnings appeared
After doing this work, I noticed three warnings that weren’t there previously:
  1. ABS fault
  2. Tyre-pressure monitoring fault
  3. Front Assist fault
[PHOTO 5 – Dashboard showing the three new warnings, including any written error messages]
For context, I already had two other warnings before this:
  • Airbag warning: The passenger-side airbag has been disabled/disconnected during the work.
  • Lighting warning: Part of the driver’s-side lighting system is unplugged while I access the fuse board.
Those two warnings were already present and aren’t the new issue.
There was no red brake-system warning light when I last checked.
The new warnings don’t disappear after starting the engine. I’m reluctant to do any further electrical testing until I know whether the wiring is correct.
6. What I’m worried about
My biggest concern is that the twisted red/blue and brown/blue pair I found behind the dashboard might not actually be speaker wires.
I know some vehicle communication circuits use twisted pairs, and I’m worried I may have cut something associated with the ABS or another control system.
On the other hand, the colours appeared to match the factory woofer connector exactly.
I don’t know whether these wires are actually part of the audio system, whether I interrupted an unrelated circuit, or whether the warning lights could be caused by a separate issue.
7. What I need help with
I’d really appreciate any advice on the following:
  1. Can anyone confirm the factory front-left woofer wiring colours and pinout for a 2018 SEAT Ibiza 6F? Ideally, does anyone have the wiring diagrams for the standard audio system?
  2. Does anyone know whether the red/blue and brown/blue twisted pair behind the passenger dashboard is definitely related to the speaker circuit, or could it be something else?
  3. Could cutting or incorrectly reconnecting this pair explain the ABS, tyre-pressure and Front Assist warnings?
  4. Is there a straightforward way to test whether I’ve cut the correct speaker wires using a multimeter, without disconnecting the main door connector or removing the head unit?
  5. What’s the best way to restore and verify these connections safely before doing any more testing? Would VCDS or OBDeleven fault codes help pinpoint the problem?
  6. Has anyone successfully installed aftermarket component speakers with separate passive crossovers in an Ibiza 6F while retaining the original head unit and door wiring? Is there any videos on this topic? I found one in German for the Ibiza 6F however they did not install crossovers and used the oem plugs.
I’m happy to take additional photos or provide any details needed.
I haven’t established whether I’ve caused damage, and I don’t want to make things worse by guessing at the wiring again.
Any help from someone familiar with the Ibiza 6F electrical system would be massively appreciated.
Thanks!
The three warnings likely share one cause. The handbook says an ABS fault lights the ESC and tyre pressure lamps too, and Front Assist leans on the same system. I'd rejoin the cut pair as it was and see if they clear, then let the OBDeleven scan name the circuit.
Not sure about the others but CAN-Bus High and Low wires are in twisted pairs. You might have broken the communication between some control units by cutting a CAN-Bus line
Edit: I remembered later that CAN always uses an orange wire, striped with another color. So I guess that wasn't a CAN-Bus wire.
Edit 2: If my eyes aren't faulting me, the wires connected to the speakers look thicker gauge like 1.0 or something. But the ones you cut look thinner, like 0.35 or so. If I'm right, this might be another tell that they weren't the same wiring.
Tal como serdar_18fr disse, quase de certeza cortas-te algum fio de CAN... Conselho, mete tudo como estava e substitui só o woofer da porta. Esquece os crossovers, se não vais amplificar e utilizar só a unidade do carro, ela lida bem com as novas colunas. E deixa os tweeter de origem que funcionam muito bem.
As "serdar_18fr" mentioned, you almost certainly cut a CAN wire. My advice: put everything back the way it was and just replace the door woofer. Forget about the crossovers; if you aren't adding an amplifier and are just using the car's head unit, it will handle the new speakers fine. Also, keep the original tweeters—they work very well.
