I purchased an aftermarket HID Kit from DianeShop on Ebay (common kit purchased by people on here), looking at the instruction booklet it recommends using a 20A fuse in line with the Ballast. Im a bit reluctant to do this as the standard headlights only require a 7.5A fuse, thus if i use a bigger fuse such as 20A (for which the standard wiring was not designed for) then i may end up frying the headlight wiring harness.
I have done a search and nobody mentions the need to change the fuse from that used as standard. Some people have mentionned the fuses blowing, but then later related this to a faulty ballast.
The other option to guarantee not frying the wiring harness would be to use a relay but if possible i would rather avoid this if its not necessary.
What have you guys done?
Cheers,
Greg
Cheers,
Greg
