20vt or 2.0 abf??? help me (NOW WITH PICS)
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
Just want to say a big thanks for all your input!
I will get pics up next week Monday maybe as the car is at my mums! Any other pics people want me to get?
Me and my mate who is a mechainc is helping me do the convertion so I need to get as much info on the convertion as possibile! I'm hoping he will join up as a member, I just have basic knowlage of cars so he could explain as we go!
Ibiza_95 I will inbox you to pick your brains if that's ok?
Anyway thanks again for all your input
one last thing fueling? What will I need to do to fuel the 1.8t?
rich
ibiza_95
1.8T MK2 Conversion
sure you can pick my brains mate...
i did exactly the same with Ben (Roly) when i did mine, so happy to pass on any knowledge, though starting with a 1.6 i dont know what parts you have, ie: the front subframe for instance, and the same with the fuel pump... however a little part number cross referencng will help you a lot
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think the 1.6 FP is like 1bar, so you will need to change that. The ABF needs a 3Bar IIRC, same as 20VT
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
im currently looking for a donor right now iv seen a passat thats fail mot on abs sensor,so i might go have a look at that! i just hope if i use a passat its as simple as an ibiza donor
You don't want a Passat - the engines are longitudinal (i.e run along the length of the car). As the Ibiza is transverse, this just means you've got more ancillary stuff to move around and fiddle with.
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
Thanks for that m0rk! is the fpr in the tank then
Ibiza_95 iv read and re read bens and martins thread to takin as much as I can so I don't go wrong i don't think iv come across yours yet but I will have a look later!
Jason long time no see, now I dindnt know that! Thanks for the heads up on that why they put it that that's a bit Irish grrrr
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
heres a few pic i took earlyer hope they help
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
aye really odd that, yet 1.4's share same 3.0 bar as the 2.0 8v+16v etc
does the 1.6 only have single fuel pipe with no return to tank or something ?
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
humm im not sure ill try get some pics with the air box off and you maybe able to tell from that,when i got an air filter a wile ago the guy said it the same carb as the 1.4 16v polo
its not every econoical though i think there is a sensor has gone but not 100% which one it is!
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
ok more pics here the pics of the carb
are these the right brakes and gear box ill need?found a mk3 golf driver
any iput will be great
rich
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Gearbox is a definate no. Controversially you may already have the right hubs and calipers. Do you have 256mm discs on there at the moment? Those golf brakes are wrong too.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Nah, has twins same as the 16v - when I swapped mine it plugged right in.
rich.h44
Its a secret!!!!
Aug 31, 2007
1,601
hull
m1keh no i have tiny breaks 239s if im corret! and as far a im aware i need to change the full hub for bigger breaks!
thanks m0rk!
