20VT Toledo now wrapped GREEN
20VT_AUQ
Roar
Dec 5, 2019
60
29
Not a fan of the new color to be honest. I absolutely love the carbon roof though!!!!
You are my reference anyway, respect to those mantaining a Tolly II in such a brand new look :)
spudboy6
722
114
Swindon
Just to keep this alive ,
the Toledo is still alive 160k miles on it roughly now , I’m in the process of having a full engine built up to manage a g25-550 but that is a long term project so won’t happen very quickly .
I canceled my black formentor vz2 310 as it was held up waiting on cameras and beats , took a car the dealer had ordered for stock which had a paint option and beats , was happy to have the car and not wait as the M140i was sold and gone and was lacking a fun ‘new’ car for the family role .
spudboy6
722
114
Swindon
So on Sunday I was on my way to look at a 2001 Ibiza Cupra 1.8T as these have always been on my list and a car I’ve known for a few years was offered to me.
On my way to view said Ibiza the RED oil light pings up on my dash , pulled over , checked oil level etc , fired it back up again and oil light has gone out , looked at the Ibiza but now have this oil light in the back of my mind wondering if my Toledo is about to give up on me after 9 years .
I do have a second engine being built but this is some way off due to cost of a fully built engine .
On the way home oil light comes on and straight back off again .
Got it to the workshop . New pick up , pressure switch , oil , filter , etc
Strainer had debris in it mainly bits of sealer ,
Main find was the oil pressure switch is leaking oil out the plug connection end so this looks to be the culprit ,
Either way so far with new parts fitted all looks to be okay but next few days I’ll see how it plays out , engine still sounds sweet and no swarf so I suspect oil pressure has been alright and it’s the switch .
Reactions: Yellow fr
spudboy6
722
114
Swindon
So I picked up a LCR today for a bargain price of £1200,
Double din
Recaro 2+2
Low owner car with the original invoice from seat from 2005 ,
Once the coolant temp sensor was swapped over it drove home 100miles without fault
I only want the recaros out of it and have already sold it on to a friend of mine to restore
spudboy6
722
114
Swindon
Just updating this as haven’t been to active on here recently .
1) new rear beam with all new power flex bushes. New hard lines , new flexi pipes , near bearings
2) LSD waiting to go in the gearbox if the bearings and shims ever turn up
3) new Godspeed front discs with ds2500 pads
4) new cambelt and water pump
5) new VVT solenoid kit
6) power flex bushed the front end and Cupra r quick rack and subframe fitted
7) recaro seats In
8) wheels powder coated in metallic lambo bronze
Heading to the Nurburgring again in September so getting it ready now :)
spudboy6
722
114
Swindon
As this years Nurburgring trip ever draws closer I decided to pull my finger out and start playing with the torpedo .
Recent mods
1) LCR arms
2)LCR quick rack
3)LCR hubs with new bearings
4)Fully polly bushed
5)Cambelt + water pump
6)Timing chain kit
7)LSD and gearbox modified to remove all brass rivets in selector forks etc
8) clutch and solid flywheel
9) ferodo DS2500 front pads and Godspeed discs
10) new radiator
11) new condenser and filter drier
12) Rear disc and pads
13) powder coated wheels and NS2R tyres
14) new cv joints
15) new engine and gearbox mounts
16 ) replaced engine bay fuel / water pipes
17 ) strip and grease coilovers and new top mount bearings
18) downpipe gasket
19) new aux belt and tensioner
20) replace all filter , air , oil , fuel , pollen ,
21) clutch pedal welded to prevent it snapping
22) new clutch switch
23) wheel alignment
Sure I’ve missed loads and there’s loads of little sundries nuts bolts and quick trips to TPS as I buy genuine where I can ,
many long days and late nights and moments where I wanted to burn the thing but battled through , I’ve totalled up and it’s cost me not far off £7k .
I’m in deep with this car now , it only cost me £1500 back in 2014 but I love it .
It drives better than ever and now it handles amazingly I’ll get the engine build back on track and done over winter .
