jonjay
50 Years of 911
Jun 27, 2005
5,837
Essex
This weekend saw a beast of a car being detailed. This is probably the fastest Pug 106 in the country boasting 450BHP, 380 of which are at the wheels in an 800KG shell! Race clutch, race cams, roll cage and differential, its clear that no expense was spared in making a car “that would scare” a lot of people once moving.
The car was sprayed over a year ago however the paint wasn’t up to the standard Dean was expecting. Dean has done a superb job of looking after the car since, regularly using the two bucket method and SRP monthly has kept the paint work in good clean condition. Of course the main problem was swirling and a plan for agreed on how we would tackle this.
Products
Wash n Drying
Meguairs NXT Tech Shampoo (body work)
Meguairs All Purpose Cleaner
Valet Pro Snowfoam
Sonus Drying Towel
Meguairs, Chemical Guys and Shagpile microfibers
Body Work
Cleanyourcar fine polyclay
Meguairs Last Touch Quick Detailer
Menzerna Power Polish (PO 203S)
Dodo Juice Lime Prime
Sealants and Waxes
CarLack 68 Acrylic Sealant
Chemical Guys Blitz Sealant
Plastics, Rubbers and Glass
Autoglym Vinyl & Rubber Care
Turtlewax Glass Cleaner
Chemical Guys Wheel Guard
Turtlewax Tyre Gel Dressing
Tools
Meguiars G220 mk2 machine polisher
Karcher Pressure washer
Snow foam Lance
Myriad of foam applicators
Menzerna Polish Pad, Lake Country Cutting and Polishing spot pads
Swissvax Detail Brush
Meguiars Wheel Spoke Brush
3M 3434 Masking Tape
Here is how she turned up.
Before
Cleaned the wheels
Cleaned the plastics
Valet Pro snowfoam
Valet Pro Snow foam cleaning ability is pretty impressive
Wash Stage
Claying Stage - as you can see AG SRP has done a superb job in keeping the paint clean and smooth.
Drying Stage – got to love the leaf blower!
Left Side Wing correction
Left Side Door correction
Left Side Arch correction
Right Side Wing correction
Right Side Door correction
right side vs ride side rear
450BHP Pug 106 Turbo Behemoth Paint Correction Detail Part 2
Wet Sanding
Rear Side arch
Roof corrected – reflectastic!
Rear Bumper corrected
Front Bumper correction
Before
After
Here are the results of the first pass with 203S. Quite impressed with the cutting and glossing capability. Just gives you that little bit more cut that the 106FA but you don’t lose the gloss factor like you do with intensive polish.
For the second stage I decided on Dodo Juice Lime prime instead of Menzerna. Reason for this was I tried Lime Prime via machine on one panel first, the results were so good I didn’t think twice to do the whole car with it. Gave a super deep gloss finish and my mrs even commented on what a difference LP made.
With this special car Dean wanted the interior machined also. Weapon of choice was Lime Prime again as many of the scratches were real deep so I went for look over correction. Worked out pretty well!
Before
After
Rear boot area
Before
Boot was machine with Lime Prime then al the interior surfaces was treated with CarLack AIO Sealant.
The car was then treated with 3 Coats of Chemical Guys Blitz spray sealant that also contains lovely canny wax.
Results
