5 stud convertors
RobertW
67
Scotland
Looking to fit a set of 5 stud audi tt wheels to the Ibiza mk3.
Anyone supply proper hub convertors????
Getting a set of tt comps very cheap so hopefully can get hubs to match :D
Martin CUK
CruisinUK.com
Jul 13, 2004
322
NW
www.cruisinuk.com
There was a thread about this on E38 today actually...
CupraT on here is thinking about fitting those wheels. Not sure what the offset is but I think it must be high enough to accommodate the 20mm of the hub adapters. :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
why 'must' it be?
because you want it to be?
I think they're about ET35, so if you slap a 20mm adaptor plate on it - who's going to have no arches left
bbsboy
89
i think the easiest way to do this is to used the hubs etc off a vr6 golf or corrado
Mark@VAGWORX
SEat Regular
May 15, 2003
401
Nr Colchester, Essex
m0rk said:
why 'must' it be?
Because it doesn't conform to the norm.....doesn't mean it can't/won't be done.
Roll the arches and you'll get a TT rim with an offset of 35 running a 20mm adaptor under the arches.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
trust me - you won't get anywhere near 20mm extra if you roll the arch, the material just isn't there to move.
Martin CUK
CruisinUK.com
Jul 13, 2004
322
NW
www.cruisinuk.com
How do you know for definite though... i hope you're proven wrong! lol
I didn't know what the offset of the TT wheels was, but I guessed it might be quite high as I knew Mark was thinking about fitting them.
In any effect, from pictures I've seen of European mk3s i'd say there is the 'possibility' of fitting wide wheels and flaring the arches...
Just a few examples:
9x16, 9x16
http://www.cleaned.be/gfx/garage/46_05.jpg
8.5x16 ET 20 & 9,5x16 ET -01
http://www.cleaned.be/gfx/garage/38_01.jpg
8.5*17, 9.5*17 et 15
http://www.cleaned.be/gfx/garage/29_05.jpg
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Now thats what I needed to do...
rolled the edges flat which did flare a little but not enough... so "other" mods employed.
wish I could do bodywork.
Mark@VAGWORX
SEat Regular
May 15, 2003
401
Well, my Rondells are 7.5x16 ET36. I'm also running 20mm spacer (per side), so effectively taking the ET down to 16. The car's set to ultra low, and there's no rubbing or scuffing on the front what so ever, and that's before having the arches rolled.
So, i don't see it being a major problem running a 7.5 Audi TT rim with an offset of ET33 with a 20mm spacer. The only difference being is that the TT rim is 17".
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
I am staggered yours clears..
stretched tyres must be the trick (for looks and clearing)
245's 35-17 on mine now.. and they WILL fit dammit! :think:
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
just the drive flange on the front... not sure about rears tho, bearing carriers on the back of ibiza... maybe mk4 golf/leon the same?
