Sep 22, 2019
7
Netherlands
Hi guys i am currently trying to retrofit my old mib1 for a mib2 with a new 8 inch screen. I found someone who can remove cp and code the rest for a good price.
I bought a MIB2 Std with navigation, part number 5QA035858B (SW 0472 & H41), i also bought the 8 inch screen, part number 5F0919606. I was wondering if the screen and unit are compatible with each other.
8 inch screen will definitely work with mib2
Sent from my SM-G986B using Tapatalk
i read somewhere that you need at least SW 0351. There are some units around (for example H24) that are only able to run at SW 0253, that is why i am confused because i also bought another MIB2 unit that is H24 (HW) and SW 0241) before i bought the H41
That's correct, it does have to be at least SW 0351. Something to do with the resolution, I think.
I would assume that would be newer than 0351. When do you plan on fitting it?
The screen is pretty easy, little bit of cutting down to do. What size screen do you currently have? I went from 6.5 to 8 bit didn't have to change my MIB unit
i still have the old mib1 so this is going to be a big step up with android auto and such
