Crossthreaded
577
168
This is going to be about my Super Capacitor Jump Starter - what's that? I'll try to inform you.
As I've been interested in these for several years now, I may have mentioned them before. However, now I've bought one I'm much better informed and some of you might be interested in my experience?
Jump starting is a subject which puts the "willies" up me, why? Well, modern vehicles are awash with Electronics and electronic components are notoriously well known for being fragile when not fed the required electric current, especially if an over voltage is the problem. Many of us will be aware that jumping car to car with conventional jump leads is a bit like playing Russian Roulette with your electronics - on both vehicles. I won't go into why as it's a long subject, suffice to say, I just don't jump car to car any more. However I do very happily jump start using a slave battery. At this time I have two "workshop" batteries. One is a big old 12 volt which was in my Cordoba 1.9 tdi somewhere in the high 70 amp hours region and too heavy to carry very far. There's also a smaller one from my boy's Punto which is around 50 amp hours and easier to transport but still not something I want to carry long distances. Both are very handy as power sources when I'm messing around in my workshop. The problem with using either of them is that they live in my garage not in my car! Not very convenient. These are also old type lead acid batteries which are not the sort of thing to be carrying around, unsecured, in the car!
The answer of course, is a dedicated jump pack. There are so many advertised on line I just didn't know where to start :ROFLMAO: - pun intended - As I started to sift through them it became immediately obvious that there are many with really quite small batteries and these seem to come in either quite conventional lead acid "flavour" or more modern Li ion types the latter being usually smaller and lighter - just a bit bigger than a large mobile phone, sort of thing you can keep in the glove box. But how, I was thinking, can something this small actually start a car with a flat battery? Well, the simple answer is it probably won't IF the battery is REALLY flat. By this I mean when you put a volt meter on it you get next to no voltage registering. These small jump packs work because very few "flat" batteries are actually "flat". They have just dropped in voltage to the point where there is just not quite enough "oomph" to energise the starter motor - You know the situation, you twist the key and there's a quite loud clicking noise from under the bonnet - this is the solenoid attempting to engage but not quite managing it as there's not enough voltage in the battery - often around 9 to 10 volts, it varies from car to car depending on the systems. What a jump pack does is "piggy back" it's voltage onto what's left in the big battery in the car and the two combined will lift the voltage enough to allow limited cranking of the engine. The smaller the jump pack the shorter cranking time it will allow. So that immediately ruled out the smaller capacity packs for my purposes.
Then I was discussing this with some motor trade friends, one of whom raised a very interesting point. You've got to remember to keep charging it from time to time. He said he goes out to cars which won't start and finds a "dead" jump starter in the boot or glovebox! also, if you don't regularly charge them and let them go completely flat they often won't accept charge. Of course my big workshop batteries sit on maintenance charge on my Smart charger so this isn't a problem with them but it would be very easy to forget to put a jump start pack on charge every few months or whatever, when it's out of sight in the glovebox or boot, so when you need it, it may well be flat.
I'm going to break here as this thread is now getting to long. thread resuming in a minute
A "Different" way to jump start - Part 2
I'm back!
It was at around this juncture that I started looking into Capacitor based Jump Starters because they are stored UNCHARGED and then, when needed, CHARGED UP FROM THE PARTIALLY FLAT VEHICLE BATTERY LITTERALY IN A FEW MINUTES! Wow! so what's that all about? Ok, as I understand it, these devices contain a bank of 5 or 6 substantial size Ultra capacitors each of which, when fully charged, reaches around 2.5 volts. The jump packs typically contain 5 of these although the more expensive ones have 6. To use it you simply connect the leads - red to battery positive on the "flat" vehicle battery and black to an earth on the vehicle (you can go to the battery negative terminal but I prefer not to to avoid the possibility of sparks near a battery which has likely been very recently under extreme duress trying to crank the engine and thus emitting gasses. To be fair, most packs won't allow this as they remain isolated until you activate them, but I prefer to be careful. Once both leads are attached you initiate charging and the pack charges up which typically takes about 4 to 5 minutes - depends on residual charge in the pack and voltage level in the vehicle battery. Then you press the "start" button and you get a count down of "beeps" followed by an extended "beep". When the extended beep sounds the pack is supplying voltage to the car battery so you twist the ignition key and the starter will crank the engine.
So what on earth is going on? how can a battery with only 10, 9 or even 8 or 7 volts achieve a charge in the pack sufficient to start the vehicle? Ok. Here's what I think it's all about. First thing to say is that most of these Ultra/super capacitor type jump packs won't charge if the vehicle battery is so discharged it falls below 5 volts. That's ok though because most vehicles which fail to start will still have enough voltage in their batteries to allow a charge to take place - if not you can charge the pack from another vehicle, at no risk to that vehicle, or using a USB charger from the mains. This doesn't differentiate them from small battery jump starters as they don't generally have enough capacity to start a vehicle with a completely flat battery either - they're just not big enough. So now we get to the "nitty gritty". You'll remember I said above that a fully charged capacitor holds about 2.5 volts? Well, we've got a "flat" battery in the car with likely about 8, 9 or maybe 10 volts in it. This is not enough to crank the engine. So, after connecting up the jump pack leads - red to pos, black to neg - and pressing the "charge" button the "clever" electronic circuitry in the jump pack connects the capacitors in PARALLEL - so it's the same as connecting each 2.5 volt capacitor separately to the 9 volt - or whatever - battery power source. of course the pack's electronics monitor the charge and when all of the capacitors are charged it cuts the connection so over charging doesn't happen. Now you've got 5 or 6 - depending on the device you've bought - capacitors all fully charged to around 2.5 volts. Next you press the "start" button and the electronics now connect the capacitors in SERIES giving you the sum of those capacitors - so, if 5 it'll be around 12.5, maybe 13 volts (in theory a capacitor could take 2.7 volts) or, with 6 capacitors, around 15 volts. I think the electronics monitor this so a dangerous current is not fed into the system with the 6 capacitor packs like mine? I imagine this is not a problem with the 5 capacitor packs? When you press the start button the unit beeps for long enough to let you get behind the wheel ready for the steady beep which tells you the reconfiguration is complete and it's time to give it a try.
I've only had my pack for a couple of months and I've "piddle diddled" around in the workshop experimenting with it and it seemed to work fine. However I used it "in anger" just the other day. I was sitting in my living room looking out the window when a car appeared traveling very slowly backwards up the road with a young lady at the wheel and a very hot and bothered looking young chap pushing on the bonnet. He saw me and gave me a wry smile. I just had to go out and say I'd love to help but can't because of my artificial knees and hip. He was fine with that so I asked him if they was trying a push start - our street is slightly down hill and he was pushing the car up the hill. Yes he said, Don't suppose you've got jump leads have you? Well yes, I said and went on to tell him how dangerous jumping modern cars can be, he still wanted to try but I said "not with my car you won't". Then I mentioned the jump pack and he was all for it - although he didn't know what a jump pack was (I don't think he really knew how to do a jump start either). I tried the starter but all that happened was the solenoid clicked Then I checked the battery with my voltmeter which showed under 10 volts (forgotten what it actually was now.) Out came the jump pack, and his wife - I think she was his wife? - was even more interested than him so I gave a very brief explanation as to how it worked because you have to wait a few minutes for it to charge up so there's time. Took about 4 minutes to reach full charge. Pushed the button (you can hear a relay inside the pack click as you do so) the countdown beeps ran down and then the longer beep. He was already behind the wheel so I told him to twist the key and the engine cranked nice and fast and sprang into life. Result. - Very impressive.
The one I bought is the Streetwise branded one:https://www.streetwizeaccessories.c...tarters/N-Capacitor-Jump-Starter-Green-SWPP20 Which I found at Argos for much less than the advertised price. I wanted a heavy duty unit and this one, so they claim, can cope with up to 8 litre petrol and diesel engines, but if you're just using it on smaller engines there are other makers offering smaller capacity devices at lesser prices. I have to say the Streetwise name put me off a bit, because it sounds kind of "DIY/amateur"? But I got in touch directly with them - the Streetwize people that is - and they were very helpful even getting answers to my questions from the manufacturer themselves. I've seen this pack in several different colour schemes - well two at least - and even on American websites. I guess it's made in a "mega factory" somewhere in the east, as so much "stuff" is these days, but seems well made and, for all the use it'll see with me, I think it likely it'll outlive me. By the way, because it contains no battery at all, the projected life span is in excess of 10 years - unlike a battery device which might go half that before the battery is done - assuming you've been remembering to charge it!
Reactions: digitaria
Just in case the above has whetted anyone's "appetite", here's a couple of videos I found interesting when I was researching this jump pack. By the way, it seems to be branded Keen Power over there.
And a very interesting one comparing a battery powered pack with it of similar capacity. I was particularly interested in the fact that both packs worked on vehicles where the battery was completely dead - albeit, of course, that both packs had to be charged separate from the vehicle being as how the vehicle battery was completely dead. I believe many of smaller packs just don't have enough "oomph" to drive the system when there's nothing in the battery at all and many won't "kick off" unless they can detect a certain minimum battery voltage. Another reason why this Streetwize appealed to me. Having to activate the heater plugs was just too much for all but the biggest pack. I suspect the Streetwize would have turned it over if it had been a petrol though - you can hear it very nearly takes it over compression even after the glow plugs had taken a toll on it. Smaller capacity engines would start I think. I'm talking about what happens at the end of the second video here.
I must admit to finding something quite appealing about the chap presenting the videos! Looks like a "no nonsense" sort of guy!
It's interesting to see, at the end of the second video, that really nothing except another nice big battery is going to get you going if the vehicle battery is completely flat. Oh well, if I come across that situation I'll just have to go back to my garage and pick up one of the big shop batteries!
Also worth saying, doing starts this way - with a jump pack or slave battery - is basically giving the vehicle electronics access to just a normal battery voltage. It's very unlikely indeed that when the engine starts there will be the risk of a voltage spike which could destroy any of the components - But I'd still recommend not disconnecting the jump pack (or slave battery if that's what you're using) until the engine has run for a while, say 5 or 10 minutes, so that a surface charge can be built up on the vehicle battery plates. Disconnecting the jump source as soon as the engine starts where the vehicle battery is very very flat (ie maybe not even allowing doors to unlock?) might well induce a voltage surge, and thus a high amperage, as the Alternator's regulator tries to compensate, which might "fry" some electronic components. It might not, and people do "get away with it" but I think Dirty Harry put it succinctly when he asked the question "Do you feel lucky"? Also interesting that the Streetwize instructions recommend leaving the pack connected until it's fully recharged which I agree with as this will let the vehicle charging system put some charge into the vehicle battery and greatly reduce the risk of spiking when the pack leads are disconnected. I think this is especially important if you're jumping vehicle to vehicle which, as I've said, I just don't do any more - unless I'm working on a classic. Never, especially if you've risked jumping from another vehicle, disconnect leads immediately after the jumped vehicle engine fires up - always leave them connected for a time. Also DO NOT turn on the ignition switch and operate the starter on the vehicle with the flat battery whilst the ignition is still switched on and/or engine is running in the "good battery" vehicle. If it's ignition is still on when you start the vehicle with the flat battery then both vehicle's electrical systems are "talking" to each other and ECUs really don't like that. It's at that moment of fire up that most damage is usually done. This runs against what us "oldies" were taught back in the day when it was common to leave the donor vehicle engine running just in case you flattened it's battery and ended up with two vehicles you couldn't start!
I've been doing a bit of "pondering" on the above. I believe, from videos and reviews I've read, many of the small battery type units won't allow connection to the system unless they detect a certain minimum battery voltage - which means they won't even attempt to start a vehicle with a substantially discharged battery. I can well imagine this is to protect their internal battery from what would otherwise amount to a straight short? When you start looking at very depleted batteries, you really need something "meaty" for success because the severely depleted battery is going to immediately rob electricity from the donor battery.
Traditionally I've overcome this by having my large "workshop" batteries as a source of power but it's asking an awful lot of a relatively small jump pack to do this. I was especially interested to see, in one of the videos, the Keen Power (Streetwize) pack did attempt to turn the large Diesel engine over even though the large truck battery was completely flat and it must have robbed a lot of the power from the pack powering up the heater plugs before an attempt to operate the starter was made. I would guess it would probably start one of our smaller European car diesel engines which would have a smaller battery to initially "rob" the pack and require less energy to turn the engine over? The big problem with diesels for these jump packs is the need to energise the glow plugs for some time before the starter is operated. Glow plugs pull a lot of current which is likely to result in not enough power being left for the starter motor. This is simply a capacity problem so you need a substantial power source to start a diesel compared to a similar sized petrol. For me personally, this isn't so much of a problem as there's only now one diesel in the family and it's just a 1.4 litre. I'm pretty confident the Streetwize will start that if needed without breaking too much sweat.
The other very interesting demonstration was using it on it's own (no vehicle battery connected) to start that car in the video. Most packs won't work unless they "see" some battery voltage when connected. With this setup though, if you run into a very flat battery, you could pull one of the battery leads so the battery is no longer in circuit. Jump the car by connecting to it's battery leads and then, before disconnecting the jump pack, pop the disconnected lead back on the battery - whereupon the alternator should put some charge back into the battery and allow the car to run - This is in fact a very old "trick" we used, back in the day, when trying to start any vehicle with a very flat battery using just a normal workshop battery. Having said that though, the best thing to then do is run it straight into a workshop/auto electricians and get the whole thing checked out because if you stop it it may not restart! Of course you'd have to charge the pack separately - either from another vehicle or using the mains usb charger (usb as a last resort because it does take quite a while they tell you) but it gives you an option not available with anything other than a large slave battery.
Please do comment and leave some thoughts on this folks. I'm fascinated to hear your opinions, especially if you have one or a differently branded product and whether you think I've misunderstood how these things work - every day's a school day I recon?
Just for your "edification" here's a quite informative video for the one being sold on t'other side of the Pond. You can see it's colour scheme and brand name are different and they make a different claim as to what size of engine it'll work with but I believe it to be the same product - Sorry for the "AI" voice on it, but even so It tells you quite a lot and, near the end, shows a cut away of the inside:
I think I've "gone on" quite enough about this whole subject, You'll have gathered I'm very enthusiastic about it. So now I'm going to sit back and watch to see if anyone cares to comment. Otherwise I think I'm done here folks!
If you're particularly interested in these, Sealey do their version which seems to be readily available over here in UK. I think it uses 5 capacitors? and there seems to be different capacitor specs which I don't understand. There's a very similar Schumacher branded version of this available in the States? Autowit is another I've come across - Scotty Kilmer seems to like them - Take a look on line, there seems to be quite a number of brands getting into this now.
Reactions: Seastormer
Yes all that info has got me wondering if the jump pack I have in my boot for emergencies will live up to it's claims, seeing as it is one of those that are just under the size of an old video tape, with a solid state Li Ion battery in. Just as well I am still covered with the AA from getting the car serviced at the dealer.
Hi @Seastormer. Thanks for the reply and I hope you are keeping well? Considering the number of views my posts have had I was beginning to wonder if I'd picked a subject which no-one was interested in!
When I worked on the shop floor I volunteered to man the recovery service we operated and for jump starts we carried an old truck battery which had the capacity to crank a smaller vehicle for many minutes if needed. This taught me that there's no substitute for size when it comes to cranking ability. Of course there's been jump starter packs with lead acid batteries for a long time but they are big and relatively heavy and require to be kept on maintenance charge if the battery is not to sulphate. Then I became aware of these much smaller capacity devices, usually, like yours, with a Li-Ion battery and I pretty much thought "how can such a small device actually jump a car"? so I really didn't look into them in any detail. Now I'm old and "creaky" and don't find it easy to lug great heavy lead acid batteries around any more so, a couple of years ago, I decided to go for one of these smaller and lighter options. I did a lot of reading up on them and came to the conclusion that these smaller packs do not indeed, have much capacity and rely on acting as "top up sources" for a battery which is only just below the critical voltage to turn the starter. They simply don't have the capacity to give enough lift to the system to crank a vehicle with a substantially depleted battery or to crank for more than a few seconds? Being, as I am, the family breakdown service, I need a pack which will give a reasonable crank time, so I started looking at the bigger packs - basically size is everything as more capacity means a bigger pack. It was when I started looking at these more expensive packs that I became aware of these capacitor based devices and my interest in them took off from there.
So I think there are "aspects" to consider. The most obvious being, as it ever was, Capacity. With the battery based devices it's not difficult. The bigger the battery the more endurance. The capacitor devices seem to come in two 2 flavours - from what I managed to find out. Those with 5 capacitors and those with 6. The 5 capacitor devices are far more common. but the 6 capacitor ones seem to claim to be able to crank much larger engines. So my thinking is that a 6 capacitor device will have more chance of acting successfully and probably be able to crank for longer. I'm also attracted to the projected life time of the capacitor devices. All things being equal, they should last very considerably longer than a battery based device.
Then there's the whole subject of charging the device. Battery based packs require periodic charging to be ready when needed. If you forget to do this then the pack is useless. It may be that you'll find this out somewhere that you have access to a power supply to plug the pack in and charge it up. But with battery based devices, that's going to take a long time, certainly several hours. With the Capacitor based pack you charge it from the depleted vehicle battery in a matter of minutes - as long as it has more than about 5 volts in it, which, in my experience, is not unusual. As a basic indicator, if your central locking has managed to unlock the doors and the starter solenoid is clicking when you turn the key then there's going to be enough charge still in the depleted battery to allow these capacitor devices to charge up - I recon that's going to be about 95% of the breakdowns of this type which I've attended. One useful feature of the one I've bought is that the little screen on the front displays battery voltage when first connected before it attempts to charge up.
Where all of these devices struggle somewhat is with diesels because of the need for them to energise their glow plugs before you crank them. The problem is again, one quite simply of capacity. Glow plugs, for those not in the know, are small heaters in each cylinder which assist with the initial ignition of the fuel when the engine is starting, especially from cold (which, of course is when the battery has to work hardest anyway) These glow plugs pull a lot of current so it's unreasonable to expect a small jump pack to deal with this. Nothing like a nice big slave battery when you're jumping a diesel!
I bet yours will be just fine with a modern petrol as they tend to be quite small capacity units anyway - unlike, say, the performance vehicles of old which perhaps had a 3 or 4 litre six cylinder (Jaguars for instance) - just remember to charge it periodically?
When I worked on the shop floor I volunteered to man the recovery service we operated and for jump starts we carried an old truck battery which had the capacity to crank a smaller vehicle for many minutes if needed. This taught me that there's no substitute for size when it comes to cranking ability. Of course there's been jump starter packs with lead acid batteries for a long time but they are big and relatively heavy and require to be kept on maintenance charge if the battery is not to sulphate. Then I became aware of these much smaller capacity devices, usually, like yours, with a Li-Ion battery and I pretty much thought "how can such a small device actually jump a car"? so I really didn't look into them in any detail. Now I'm old and "creaky" and don't find it easy to lug heavy great lead acid batteries around any more so, a couple of years ago, I decided to go for one of these smaller and lighter options. I did a lot of reading up on them and came to the conclusion that these smaller packs do not indeed, have much capacity and rely on acting as "top up sources" for a battery which is only just below the critical voltage to turn the starter. They simply don't have the capacity to give enough lift to the system to crank a vehicle with a substantially depleted battery or to crank for more than a few seconds? Being, as I am, the family breakdown service, I need a pack which will give a reasonable crank time, so I started looking at the bigger packs - basically size is everything as more capacity means a bigger pack. It was when I started looking at these more expensive packs that I became aware of these capacitor based devices and my interest in them took off from there.
Thanks for the reply, I do check the jump starters every month (the MIL has one too) and they take ages to drop from 100%, so seem to keep the charge well.
Reactions: Crossthreaded
That's interesting to know. I suppose a Li Ion is going to deplete much more slowly than an older technology battery. I've noticed my boy's power tool batteries, Li-Ion, keep charge for much longer than my older NiCads. I got a nasty shock the other day when I went to use my Camera - quite a "nice" Panasonic Lumix - but found the batteries (I have two) completely flat. Neither battery would accept charge, which I thought strange, so I phoned up my friend who is a camera enthusiast and he told me that I'd be better just buying new batteries as Li Ion batteries are damaged by allowing them to become completely discharged and, although there are things you can do to try to recover them, for me, the easiest thing to do would be to just forget them and buy new ones. Looks like a "known brand" is around £20 each, so not a crippling price, but I'll be taking better care of them from now on.
Well. Here we are just a couple of days later and I certainly can't say that now!
No-one has yet owned up to having one though? - Seastormer's is a battery device.
I meant to comment here but got distracted. I have cover for the Panda with Britannia and the Scala, being a little less than 18 months old, is still covered by Skoda. A jump pack is just one of many "get out of jail cards" you might consider investing in but is no replacement for breakdown recovery. ;) The complexity of modern vehicles makes attempting any but the very simplest of repairs at the roadside a pretty pointless ambition. I've always carried a few emergency items, top up oil and coolant, hand cleaner, spare bulbs, etc but I now only have a few tools in the boot whereas previously I had a bag of them in beside the spare wheel.
How about you, do you go around with a bag of tools in the boot?
I still have a few basic tools, but I do have a racing trolley jack, a couple of A to Z maps, oil, coolant, WD40, paper towel roll, foot pump, wooden wheel chocks, long wheel brace, 1/2 inch drive battery wrench, waterless wash (for bird droppings etc), first aid kit as well as my jumpstarter, so not really an average boot load.:LOL::LOL: And no I was not in the boy scouts, just the boys brigade, but I like to be prepared.:whistle:
  • Love
Oh, I envy you the racing trolley jack. Often thought about one just to keep in the car but, as I have 2 big and 2 smaller ones of the heavy steel variety in the workshop I just can't justify the extravagance. AA maps live under my Mrs front seat. WD40, a 2 litre of ready mix coolant 2 litres of ready mix screenwash and 2 litres of water, all in "pop" bottles, for stuff like bird poo etc and a small sponge. Engine oil, fuel additive, spare bulbs and fuses, a squeezy bottle/tube thingy of Comma Manista and a roll of blue paper towel, There's also an ice cream tub with a smallish torch, a multimeter, a length of electric wire with croc clips at each end, a super bright LED flashing beacon thingy which is magnetic to put on the roof if we break down on a "Smart" motorway and spare batteries. Finally, a fire extinguisher which is about the same size as the pop bottles. All this is very carefully packed in a robust cardboard box at present but I'm looking for a suitable plastic box for it. An electric tyre inflator lives in one of the side pockets on the boot along with a couple of very nice metal wheel chocks which were part of the tool kit of my old Datsun 120Y estate - she had to be scrapped due to rust but I kept the chocks. I keep an 18 inch power bar with a 17mm deep socket for doing wheel nuts in with the spare wheel - the socket being wrapped in a double layer of electricians tape to protect the alloys. I like a power bar because you can use it at right angles to slacken/tighten the nuts and swing it round 'till it's straight when you can spin it between your fingers for rapid winding in and/or out of a thread. That's where I also keep the small number of tools. Now there's the jump starter too, which is actually quite bulky so has to live in the boot with the box of other stuff. In total it's probably, all together, using up about a quarter of the available space. Oh, and I keep my old Barbour jacket folded in half on top of it all so nothing in the box can contaminate anything "clean" which my better half might put there. The Barbour is also useful if something happens when it's raining. Oh dear, I think there's probably something mentally wrong with me! By the way, I decided not to put the jump leads back in the garage, even though I now have the jump pack, because jump leads could always be used as a temporary earth lead if needed - they live in with the spare wheel.
In the 'old days' I used to have spare points, condenser, coil, general bits inc 12V test lamp, some wire and basic tools. You could (barring a major catastrophe) almost guarantee to get yourself going again if you broke down.
Aye, points, condenser, HT leads, coil and others - well perhaps you could keep a coil but good luck with trying to change one of those on an EA211 at the roadside?
Reactions: Yern
I also have the small jump started battery pack but it also doubles up as a usb charger for mobile devices. I would also add I purchased it after the car just died, no lights working nor dashboard and any electrical function and car started first time after connecting.
In the boot is a proper spare wheel (as well as the small emergency one), Racing Jack, Tyre Pressure Gauge / Pump (using either battery or cigar socket), Allen Keys spare wheel nuts, Temp sensor (used on track days), Coolant and Oil top ups and several bottles of water (for windscreen topup)
After reading your list of your boot I remembered I too have fuses (no bulbs as car all LED) a torch and fire ext also, what are we like. The last time I actually broke down on my bike or in the car was over 20 years ago, so motors are a lot more reliable now if you keep the service regime up to date, and that's why IMO SEAT/CUPRA give you another 12 months free breakdown with your dealer service.
Thought I'd just mention that in beside the spare wheel I have a length of steel rod which is just the right diameter to slide into a wheel stud hole in the hub, It's about 8 inches long? When changing a wheel I put this into one of the holes in the hub where a wheel retaining bolt would fit and move the hub flange round until it's at 12 o'clock. Then I lift the wheel with one hole at 12 o'clock and slip it over the rod, thread the other bolts onto their holes just finger tight and pull the rod out of the hole so I can fit the last bolt. It makes fitting a wheel, when you're old and not so strong any more, much easier.
