mine are a lot lower than 75mm there vmaxx, i know some people may say bad things about the springs, but the coilovers, well i havent had a problem with them and theyve been on a while.
the reason that you need to get shortened drop links mate are because the standard ones are to long and when you deck it then it is likely that they will knock against your driveshafts.
if im right which i think i am the droplink is what connects the anti roll bar to the suspension.
the top mount on the front coilovers wasnt big enough to fit over the internal shaft (see pic) and had to be bored out about 2mm all round got there in the end but it was a pig of a job!
so beware your gonna need a grinding stone to bore it out!
anyway got there in the end with some serious slammage!
ARB and driveshafts have miles of clearance gave it a boot about and no knocking and full left and right full lock
no adjusters in the rear - the way it should be lol
good quality kit and not too choppy only downfall was the top mount hole not being big enough!!
