fr-tdi
Detailing freak!
Feb 7, 2008
853
fife, scotland
yum yum!
gonna try batter them on at the weekend :D
*edit*
lol or maybe not
£230 off ebay, T.A technik had a rake about the net and apparently theyre FK rebrands :S
getting fitted at half 5 so ill let u guys know what theyre like
mine are a lot lower than 75mm there vmaxx, i know some people may say bad things about the springs, but the coilovers, well i havent had a problem with them and theyve been on a while.
Chris
Hey, those look identical to mines... maybe it's TA-Technik I have too... will check it out.
Remember also to fit shorter drop links if your dropping the front a lot, or you'll find the ARB rubs off the driveshaft.
Just looked at the vmaxx kit and it recommends drop links are used
what are drop links and what are they for anyone know?:confused:
Interested to know as ive just ordered an eibach pro street s kit would
I need to order these drop links or would they come with the eibachs.
the reason that you need to get shortened drop links mate are because the standard ones are to long and when you deck it then it is likely that they will knock against your driveshafts.
if im right which i think i am the droplink is what connects the anti roll bar to the suspension.
Cool didnt quiet understand what they were for so is that only with the vmaxx kit that shorter drop links are required or with any coilover kit?
JESUS!!!
what a job!
hit a major problem along the way with this kit!
the top mount on the front coilovers wasnt big enough to fit over the internal shaft (see pic) and had to be bored out about 2mm all round got there in the end but it was a pig of a job!
so beware your gonna need a grinding stone to bore it out!
anyway got there in the end with some serious slammage!
ARB and driveshafts have miles of clearance gave it a boot about and no knocking and full left and right full lock :p
no adjusters in the rear - the way it should be lol
good quality kit and not too choppy only downfall was the top mount hole not being big enough!!
