AAAAARRRRGGGHHH - EPC/TB/EM/RPM Hunting...
petle91
Hi All,
Having a bit of a nightmare.
The EPC light came on the other day, but turned engine off and on again and all was fine until last night.
On the journey home, the car had a judder and then the TC and EPC lights came on and would only give me about 3500rpm.
Stuck VAGCOM on when home and no faults, went to go and get fuel but as soon as the ignition was on EPC/EM/TC lights came on. Plugged in VAGCOM and got some TB faults. Checked on here and most people have resolved this by cleaning the TB, did that this morning (it was filthy) performed a TB alignment but then the same problem occured. Went to check the TB on group 060 and the adaptation field was showing 'ERROR'.
Now I'm stuck! Should I take it to a stealer? Any quick fixes so I can drive to a stealer?
Any info much appreciated.
VAGCOM info below:
VCDS Version: Release 908.0
Data version: 20090830
Wednesday,02,September,2009,10:13:26:46486
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ3R140139 Mileage: 168810km/104893miles
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 MJ
Component: 1.8L R4/5VT 01 0003
Coding: 11510
Shop #: WSC 80179
VSSZZZ1MZ3R140139 SEZ7Z0C2042168
5 Faults Found:
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - - Intermittent
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-00 - -
17951 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Small
P1543 - 35-00 - -
Readiness: 0110 1100
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001 001 00001
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00041
Shop #: WSC 06402
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06441
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 922 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05424
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
Part No: 1C2959802A
Component: A7 Tõrsteuer.FS KLO 0009
Part No: 1C2959801A
Component: A7 Tõrsteuer.BF KLO 0009
Part No: 1C0959811A
Component: A7 Tõrsteuer.HL KLO 0009
Part No: 1C0959812A
Component: A7 Tõrsteuer.HR KLO 0009
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1M0 035 186 F
Component: Radio 0001
Coding: 00403
Shop #: WSC 06402
End ---------------------------------------------------------------------
petle91
hmmm, could be battery I guess (still on the original battery from new), I remember the battery light did come on and the battery cut out during the journey home yesterday.
is it possible to check battery voltage via VAGCOM? What should the voltage be?
Any recommendation on battery?
petle91
right then, new battery on.
still 'ERROR' in adaptation field when in group 060!
still rpm hunting
only 2 faults in engine section now though:
P1579 - 35-00 - -
P1543 - 35-00 - -
anymore ideas anyone?
thanks
upjoshs
sorry to bother u and bring up an old thread im new to this and iv owned seats for a while . . my 01 ibiza 1.8t but im having that excat problem and have spent good money on throtle body stealers took a look and still dont no stil the fault remains please help any 1
upjoshs
please its been a month and am desp to get her back epc tc and em lights all on now and again any 1 no
any thing ???
leonbcb
i have problem with rpm
throttle starts open/closing at idle sometimes and the rpm from 600 to 1300
any ideas?
