steve22
Just wondered if anyone knew the torque value for the big end bolts. Ive got a feeling its 65NM but not sure if this is the mains or the big ends. If anyone knew this would be great!!! Cheers in advance :D
Notes Specified value Measured value
Tightening torques
Cylinder head instructions *
Cylinder head
Renew bolts Yes *
Stage 1 Tighten 40 Nm *
Stage 2 Tighten 60 Nm *
Stage 3 Tighten 90° *
Stage 4 Tighten 90° *
Other engine tightening torques
Main bearings Renew bolts/nuts No *
Main bearings Stage 1 32 Nm *
Main bearings Stage 2 65 Nm *
Big end bearings Renew bolts/nuts No *
Big end bearings Stage 1 30 Nm *
Big end bearings Stage 2 90° *
Oil pump to cylinder block 20 Nm *
Sump bolts 25 Nm *
Sump drain bolt 40 Nm *
19 Flywheel/driveplate 60 Nm+90° *
Clutch pressure plate 25 Nm *
19 Crankshaft pulley/damper centre bolt 90 Nm+90° *
Camshaft sprocket/gear 65 Nm *
Camshaft carrier/cap 15 Nm *
Camshaft/rocker cover 10 Nm *
Inlet manifold to cylinder head 20 Nm *
Spark plugs 30 Nm *
Lambda sensor (Oxygen) 50 Nm *
Knock sensor (KS) 20 Nm *
Chassis tightening torques
Front hub 265 Nm *
Steering track rod end 35 Nm *
26 Brake caliper to carrier Front *
Brake caliper carrier to hub Front 125 Nm *
Brake caliper to carrier Rear 25 Nm *
Brake caliper carrier to hub Rear 65 Nm *
Back plate to hub Rear 60 Nm *
ABS sensor Front 10 Nm *
ABS sensor Rear 10 Nm *
Manufacturer: Seat Model: Ibiza (93-99) 2,0 16V Engine code: ABF Output: 110 (150) 6000 Tuned for: R-Cat Year: 1996-99
Road wheels 110 Nm *
Use new nuts/bolts.
Girling = 35 Nm VW = 25 Nm.
Tightening sequence
this should be what you need let me know if you need more ok
Does anyone no the torque setting for the sub frame, steering rack lower arms? on a 2004 cupra tdi?
many thanks
