speedygti8v
i can't get my abf to run in a mk2 golf its all wired up right, got new crank senser, dizzy, plugs and a different ecu. it fires when your first try it but cuts out then if you keep turning it over it won't start then stops every now and then like its firing halfway up the cylinder and tring to send the piston down when it should be coming up if that makes sense. i've connected up a timing light to the king lead it will flash randomly maybe 3 times then a gap of nothing its the same when you connect a led test light up to the signal wire from the ecu help i am stuck
