ABS faults
Olly20VT
1,234
Stroud Glos ,England
It all started when I changed a AC pipe in the engine bay, I had to unplug the 3 fuel lines (next to washer bottle) and the coolant pipes that go in to the bulkhead, all put back fine and car runs fine even the AC works now it's be filled up. BUT now I'm getting these faults and ABS TC lights on dash......
Control Module Part Number: 1J0 907 379 AF
Component and/or Version: ASR 20 IE CAN 0001
Software Coding: 13404
Work Shop Code: WSC 00000
3 Faults Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-10 - - - Intermittent
16-10 - Signal Outside Specifications - Intermittent
00285 - ABS Wheel Speed Sensor: Front Right (G45)
I've had the wheels off both sides and check for stones/gunck stuck in the router sensor both clean, the wires looked ok.
Is there anything else i can check or could it be anything else none ABS?
I don't want to spend aload of money on parts to find it was somthing simple.
Also is "front right" viewed from in the car or from the front i.e front right = drivers side?
Olly
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
faults coincident with aircon pipe change? oppostite side to the wheel sensor reporting issues..
any earths disturbed?
unplug and plug in abs unit.. any iffy connections?
Front left is passenger side frotn wheel not drivers
Olly20VT
1,234
I've looked at all wires and apart from a very small nick on the driver side everything looks ok.
Were is the ABS unit plug?
I didn't clear the codes and went for a drive, stopped for an hour then when i started the car up to drive home the lights didn't come on and stayed off for the 2 mile drive home.
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
look at the block where all the brake pipes go in. there is a electrical connection on the passenger side of it
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
If you have disconnected any abs wiring with the ignition switched on of had the vehicle on a ramp running with the front wheels spinning then it will log a code, it needs to be driven over abour 15mph and should clear the codes it self. But as you say uve cleared the codes using vagcom and it hasnt came back on yet so i would just keep trying it and see.
Olly20VT
1,234
I cleared the codes the other day and they came back then i had the wheels off and checked every thing and cleared them again and they came back but now the lights on the dash have gone by them selfs but i havent had time to check them with vag-com.
I will check tomoz and then see what happens, i am getting abit consered as im off the germany in 2 weeks time.
I'll keep you all updated
delboy21
74
sensor
if your after a sensor euro car parts do a macht one for about 9pounds wont get it cheaper anywhere
Olly20VT
1,234
OK I've ordered a sensor so should be with me in a day or two, BUT i got in the car today and the battery light came on and the ABS light went off. Got home and plugged vag-com in and there were no new codes in any section just the front left ABS sensor code any ideas about this anyone?
Olly20VT
1,234
OK here is a update, my ordered with ECP's failed because I didn't fill in my bank details properly :whistle:
But as I've said my battery light came on and after a day of driving it died, so took it to my local garage who said (as i suspected) the alternator had gone so as I had a spare I got them swapped over and all is well. I cleared all codes and none have come back after 2 hours of varied driving and the car goes so much better now pulls harder. Makes me think the ABS sensor is more sensitive than the battery light, so came up first.
See how long it lasts.
