ABS Sensor? maby? who knows?
Tizer
133
Kent, Canterbury
well hopefully you do lol.
Just drove into Tesco car park (as you do) when i quick ticking sound hapened and when i tried to put my foot on the break i only had minimal breaking, a resistance pressing the peddle up (this was vibrating to the ticking) and the ABS,TCS, and (!) came up!. So obviously i used the handbracke to stop, all the lights went off and so did the noise.
Not the first time it has happened but i cant seem to get to the bottom of it as it only lasts about 5 secs.
TA!
//Rich
tommy2008cupra
hi did you ever find out wat it was? because the light only seems to come on when boot it then goes off shortly after but i constantly get that "tickling" sort of thing when i brake i suspect new brake disks as they are quite worn and maybe a dirty abs sensor or loose connection is bringing up light?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
read it for codes; only way to know. ANd even then it can be a real bitch to sort out. I've tried cleaning connector, sensor, rewired the sensor and still getting permanent code; although now abs doesn't randomly kick in anymore.
brakes being worn shouldn't make abs kick in though. check wire for wearing against tire for instance
tommy2008cupra
ok i will the tickling feeling is that the abs then? sayign that i have recently had all my camber alligned so mav have unlodged a wire etc, what wire would i be lookin for stupid question i know maybe a pic if poss?
tommy2008cupra
update checked my abs cables and there is a big gash out of nearside u reckon this would cause the above? anyway i taped it up and moved it now so fingers crossed
Jan 8, 2008
528
Portsmouth
Definitly, mine did the same, got caught on the driveshaft and ripped clean off eventualy! Had to make up a new bit of wiring to reattach it!
Should be fine now??
tommy2008cupra
cool well update i still seems to be doing it a bit, not quite as much but still there:confused:
il have to have a proper look on saturday and try and sort it out, but it only seems to be on rough ground or a bump were it almost feels like it rubbing or grinding which can be felt through the peddle?
tommy2008cupra
further update..lol took my n/s wheel off and cleaned off some crud from the sensor which seems to have sorted it for now but it started raining so i will check the other side soon but it has defo helped anyways
tommy2008cupra
right ok problem has now been solved fingers croosed took of p/s front wheel and the plug goin to the sensor with two wires on it to my horror one of the wired was hanging on by a thred so sorted it out and no more lights or abs kickin in \o/ ye boi
