Arnie Arnison
Hello,
First post on here and I could use a bit of advice as I know nothing about cars apart from driving them!
I drive an 04 Ibiza Cupra TDI with 70k on the clock and recently the TCS/ABS warning light has been coming on but wierdly only after exactly 10 minutes from turning the engine on.
If I turn the engine off and on again the warning light goes out but comes back after 10 minutes. I have not noticed any performance difference or strange noises that I can remember.
I had a diagnosis run by an VW Group specialist garage and they found the following but didn't know what to do:
17911 - DF Alternator Term Implausible Signal
18265 - Load Signal Error Message to ECU.
Any thoughts, help would be appreciated!
Cheers,
Arnie
Hello,
Cheers,
Arnie
Hello,
Cheers,
Arnie
I had my TCS/ESP light come on constantly recently, the dealers replaced the ABS sensor which fixed it.
Does your TCS still work when the light is on? As all mine stopped working.
Blimey how many different forums have you posted the same question in ???
Sure this is the 4th or 5th time I've seen it.
Can't remember which one I posted the solution in now.
Thanks idge, my TCS still works.
muddyboots.....bit of an overkill I know, put it on all the forums I thought were relevant, didn't know which ones got used the most. Thanks.
