AC Button on Climate Control
Shunter
Despite reading the handbook cannot work out why there's an Air Conditioning button on the Climate Control panel on my new Cupra. Surely with climate control on auto you do not need to adjust anything else?. Tried switching it on and off when on auto and does not seem to make any difference. I don't remember a similar button on the old Cupra.Any ideas?:shrug:
andycupra
status subject to change
im sure there was a button on the old cupra. (ECON)
Its quite simple.
Climate control maintains the selected temperature, this may mean heating the air via the heater matrix, cooling via the air con, or you can simply allow the ambient temperature to surfice by leaving it on low.
However, air con uses extra fuel, and if on all the time then the ambient temperature this is not an option as it would get colder and colder if you had it on low. So you can use climate control but have air on off to potentially save fuel if heating is not needed, but cooling isnt either.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
It de activates the a/c much the same as the older econ buttons used to.
So you can have it on cool but not running the a/c, or you can turn on the a/c when the temp is higher to clear windows faster for example.
Shunter
Cheers guys - you are right Andycupra there was an ECON button on the old one. looks like i will be switching the ac off - especially as i have the panoramic sunroof to cool things down as well in the summer. :D
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
It doesnt make a whole lot of difference as they are constantly driven compressors anyhow.
