hey guys i can hear a loud vibration from the left hnd side when i put my foot down in 1st and 2nd gears any clue as 2 wat it is sounds like it coming from the front left tyre?
could be wheel bearings?
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Check your coil for a small crack. Meaning remove and inspect, the cracks usually show in the underside.
Usually will get worse in the wet or when yuo've just washed it.
Failing that temperature switch if it is none of the more obvious stuff like ignition electrics and vacuum lines etc.
Not mate, clutch is fine and the revs dont drop....i am starting to think it may be the decat.
Head Gasket is on the to do list....hopefully no longer than 4 weeks away so will see. Its getting worse though.
Dont know becuase if i hold the revs at about 3k for a few seconds it clears.....and i am thinking that if it was that, holding the revs would make it worse.
I blew a head gasket on a saxo vtr once and it used to blow water caps clean off becuase the presure was so high....haha....
