actuator seal
cupra_jobe
158
i noticed the other the seal on my actuator is split and leaking air.....
Question one is this easily replaceable? if so where from
also when i boost to about 1.6 bar after around 2-3 seconds it drops suddenly to 1.2 could this be because of the leak. or the way it has been mapped and i havent noticed it. I no it peaks at 1.6 and the runs at 1.2 before dropping off at the end of the revs. i just thought that between 1.6 -1.2 would be smooth drop.
Any help greatful cheers
cupra_jobe
158
Sorry am not quite sure but cr turbos hybrided it around 2 months ago. I say seal it's actually a rubber bung that goes around the arm coming out of the actuator.
cupra_jobe
158
Yeh it leaks through the seal and as I prod it the seal closes up and seems to stop leaking or leaks less
cupra_jobe
158
Is it easy to do? Where do I get one just ring CR? Could this be part of my pressure issue?
