Hi Everyone, I have only had my LCR 225 with front Recaros
For a couple of months, noticed the shocks not coping with the bumps and its a bit wobbly at speed, also turn in is not sharp. Shocks have not been changed & have 91k under them.
So time to renew I think? As i also need to service the brakes I do not have a lot of cash & it's a daily driver, so coilovers are off the menu for these reasons. Would the following setup be good to improve corner turn in and fast road handling but still maintaining commuting comfort?
Eibach 22mm / 25mm arb - got already from DPM
S3 strut brace - got already from TPS
OEM LCR shocks from TPS
OEM LCR Top mounts
Audi TT roadster front rear wishbone bushes
KW cupraR specific lowering springs
dont care about stance only improving handling, do springs have to match shocks? In which case would kw springs and damper set be better? I had koni yellows on my civic vti and was not impressed
As the ride was un-even and to hard even on the softest setting, might have been the tenzoR spring. So I am rather confused on what will be best.
Look forward to your replies.
Sent from my Nexus 7 using Tapatalk 2
OEM LCR Top mounts
