aftermarket head uint install problems
saxonlad
Surrey
Hi,
I have been trying to install my aftermarket head unit and i have go all the parts needed and the wiring harness doesn't have steering wheel controls by the way. I have everything pluged in why wont the head unit turn on?
please help
Thank you
koush
292
Churchdown,Gloucester
Hi,
If you bought a wire adaptor with the steering wheel control, you need to run a separate ignition wire to the fuse box, or get an adaptor with steering wheel controls, as it has the can is box to switch your head unit.
Koush
saxonlad
Surrey
Hi,
Koush
Hi
So if I have the wiring harness with steering wheel controls I can just plug it in and it will work.
If so do you know what part it is?
koush
292
Hi,
Yes it will be plug and play. but follow the instructions carefully as i believe if you connect the power to the unit before you connect the steering control lead, the steering wheel control will not work, just follw the instructions and you should be ok. the part you need is this;
http://www.connects2.co.uk/Product/ProductItem/CTSST001.2
Its not cheap, but if you look around on ebay you might find one around £50.00 or less. CTSST001.1 will also work.
Koush
