I have been trying to install my aftermarket head unit and i have go all the parts needed and the wiring harness doesn't have steering wheel controls by the way. I have everything pluged in why wont the head unit turn on?
Hi,
If you bought a wire adaptor with the steering wheel control, you need to run a separate ignition wire to the fuse box, or get an adaptor with steering wheel controls, as it has the can is box to switch your head unit.
Hi,
Yes it will be plug and play. but follow the instructions carefully as i believe if you connect the power to the unit before you connect the steering control lead, the steering wheel control will not work, just follw the instructions and you should be ok. the part you need is this;
