Hery guys and gals!
I'm searching for the proper part number of one of the air con pipes in the air con system on the Leon FR CR170, my label on the original isn't in good condition so was working with half a part number, starts with 1** 82* 721 CA the * are what are missing due to scratches on the label from the looks of it another part to it under VWA says MFQF I believe? This pipe has a sensor plug that screws on to it if that helps?
So far the only part number I can find that seems to fit that plus looks correct from pictures is 1K0 820 721 CA. I've found a few that I am considering making a purchase of but when I checked the compatibility it stated that one of the ones in particular says it's from a Skoda Yeti Mk1 exactly same part number but states it isn't compatible with my car? Says "Trim Level: ELEGANCE TDI CR 170" from a 2010 model so I was under the impression that it would be a straight swap given that the part numbers look the same?
Thanks for the time reading and hopefully someone will be able to help put me on the right way!
--Lee
--Lee
