airbag warning light vagcom cant clear
woody1986
mad as a box of frogs
Oct 21, 2008
106
Derbyshire
Did some work on the car the other day and found that airbag light was unplugged, low and behold plugged it in and it was on constantly. so plugged into vagcom and got this error
00588-airbag igniiter driver side (n95)
32-00-resistance too high
tried to clear it and it worked for 1sec then light came back on ran vagcom again and same fault came up.
anyone any ideas how to solve this?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
investigate/check/test/fix the airbag igniiter driver side i guess ?
check wiring for a cut/short too
woody1986
Oct 21, 2008
106
Derbyshire
i know there is a few wires goin into the steering column that look like they have been cut and taped together im wondering if one of these attach to the igniter and need sorting? :confused:
on the plus side there were no other faults on vagcom!!
spose this is the perks i get for payin 600 quid for a car with little history[:@]
woody1986
Oct 21, 2008
106
Derbyshire
just looked through the wiring diagrams in my haynes manual and it doesnt state anything for an airbag circuit no relay no wiring nothing does anyone know which colour wires go to the drivers side igniter?
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Happened to me, is the wire connected to the air bag in the steering wheel?
Happened when I fitted my OMP steering wheel, had a resistor with it but didn't work.... ended up covering in light up with some tape lol. But when vag com you can switch it off but I haven't got around to doing it.
