Airbag warning!!
The other day I started the car and the airbag light stayed on. Switched car off again and left it a few seconds and restarted....hey presto....still on [:@] :censored: This went on for a few hours using the car in town.
Anyway, while later used the car again and all is fine, operating as normal. Seeing as I have no knowledge of all things electrical :redface: i'm wondering if anyone has any ideas....
...should I get it checked? it's odd as it's never happened before or since, wondering if there is a dodgy sensor somewhere, or loose wire...?
Any advice appreciated.
Cheers :confused:
allycupra
The switch in the glovebox for turning off the passsenger airbag can sometimes cause a sporadic fault as the terminals sometimes become poorly connected your dealer should be aware of this.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
get it checked out asap imo.
use vag com or go to a local dealer... ur under warranty so no problems there! :yes:
i know on my 05 LCR its ok to check the air bags with vag com, but make sure u check urs is ok as i know with a few odd cars its risky using vag com to open up the control module as it can leave the light on the dash on permanently!
