Did you manage to sort out your car?
It’s booked in to be checked again by the garage september 8-9th.
It’s working most of the time as supposed but acts up sometimes without any obvious reason and then (by turning of sync) I can change the left temp by changing the right side temp…it’s always about left side too hot.
I have seen my issue return once again, AC randomly stops working then somehow magically works again. I can go a couple of weeks with no issue then it will return. Anyways I have a service booked for the 1st so will let you know what they say.
Reactions: Hampa1
The issue I was facing was due to the AC being over pressurized. Too much gas which caused the AC to stop working. Hopefully I don't see any more issues.
Interesting, thanks for updating.
I haven’t heard about that before, assume it’s a factory fault.
Will mention it to the garage next week when I leave my car there.
This must have happened when they changed the pressure sensor (AC was not working when car was delivered to me ) last year .
Finally got it fixed!
My problem was that left side was hot whilst right side kept the temperature I set.
It turned out to be a hardware issue (as several Youtube videos indicated could be the problem). I’m not sure what the correct English term is I but think it’s called an actuator. Something was broken/was misaligned or similar.
I was able to show the issue to the service manager this time and he immediately understood that it wasn’t normal.
Happy again and that will hopefully continue!
