damn post 2000
pre 200 is my specialty
but here goes...............
remove the door mirror controls, just clipped into the door card
you also need to remove the internal door handle trim plate, to do this the finger plate needs to be removed first, the rubberised part thats peeling
in the D section pulls out! with this out the trim plate with the window switches will now lift out? it may need a bit of effort as it's clipped into the main door card! unplug the window switches and
store the plate somewhere safe
with this out of the way you should be able to some large phillips headed screws? remove these and
store safely as you'll need them later
now the fun bit
removeing the door card! its held in place by several push in clips around it perimeter there are two schools of thought on
how to remove this!
1. gently prise the card away from the door using the correct tool! or the wifes best fish knife
filler knife, putty tool etc
2. push the door car up and it should slide up enough to allow the clips to slide out of the slots they fit into? if you do this you will still need to remove the clips and locate them back into the slots so you just locate the top edge of the card in the window slot and pop it back into place using the flat of your hand!
right if you now have the door card off in one peice? you candnow see the vapour barrier? DO NOT CUT IT!
if you need to remove it to gain better access to the doors internals? run a sharp blade between it and the door cutting through the adhesive/sealer like your filleting a fish! that way you keep it in one peice, it will fit back with out any holes or tape holding it togther and it will do it's job of keeping moisture out of the car better
right then, you should now be able to see the speakers? if so there are a four screws holding them in place IIRC remove these and pull the speakers out of the door, replace with ....... X brand speaker...... oe speakers are 17cms DIA IIRC?
good luck and depending how you remove the door card? it may be worth a trip to the
dealers to get a few replacement clips are your sure to need some
