alignment
RUM4MO
7,820
996
South Scotland
anyone running them camber adjustable bolts that eibach do?
if so they any good? might have to get some cos i am running silly amounts of camber now
http://www.venommotorsport.com/prod...facturer=Eibach Alignment&category=Suspension
them beasties :)
I think that you are getting confused, the only ones that I could find were for the 6K Ibiza as they do have what is called "camber adjusting bolts" as standard but I believe that you can buy some that allow for even more adjustment to take care of excessive camber that comes with dropped suspension. Your car will be a 6L Ibiza!
RUM4MO
7,820
996
South Scotland
http://www.venommotorsport.com/manu...n&product=FrontCamber&make=VW&model=Polo Mk 6
I know but I found them for a polo 9N which I believe has exactly the same suspension setup. Considering everything else I order is off a polo 9N lol. I'll look into it further
Don't give up, but the illustration is definately not for a 9N Polo - that is for a 6N Polo - same as the Ibiza 6K I was referring to! How confusing is that, I would not have expected that from a reputable suspension seller! These certainly look like the excentric bolts used in the set up shown in the illustration, again for use with 6N Polo and 6K Ibiza.
DEAN0
Old Git
Feb 1, 2006
5,291
303
Preston - UK
Any more luck on this. From what i found out the mk4 has no adjustable camber, you just have to eat tyres lol
You can change the camber but it's not the easiest job.
If you dont have a CUPRA - you can use cupra wishbones - they are slightly shorter.
Failing the shorter wishbones - you can have the outer ball joint bolt holes slotted to reduce camber.
This is what I did - My camber is now -0.5 deg per side.
vroomtshh
4,222
Dreghorn, Scotland
Or have the top mount holes slotted. Thats what I did, and also run 0.5 deg per side
