i'm in the process of fitting my silicone hoses to replace all bar the lower metal centre pipe...
basically Awesome provided me with a SAMCO one piece top pipe from SMIC to inlet and lower 90 degree bend on the lower section of the SMIC, plus I got SFS to send me a compatible turbo outlet pipe.
all will be fitted next week when i get my new o-rings
this is most probably the closest you can get to a "boost pipe kit" for the mk4 TDi 130PD's
Done mine today with the shopping list from celoader
Sent from my GT-I9505 using Tapatalk 2
here is the parts i bought
The connectors to the asv/egr is 63mm-54mm and the intercooler is 60mm-51mm
Thats the hose from the turbo
The only thing is the connector to the intercooler is 51mm on the hose side but ive clamped it up and it seems okay
Can I ask why you didn't chose to build your own turbo outlet pipe? Secondly, what length aluminium pipe did you buy?
I havent bought the turbo outlet pipe yet and the pipe lengths for the tubing is 100mm and 300mm 60mm outside diameter
What do you mean buy alluminium connector the asv/egr and intercooler connections
